Differentiating Inverse Functions
The discussion revolves around differentiating inverse functions, specifically focusing on the function f(x) = x^3 + 2x - 1 at the point where a = 2. Participants are exploring how to find the derivative of the inverse function and the value of x that satisfies the equation.
  • Participants discuss the method for differentiating inverse functions and question how to solve for x in the context of the given function. There are attempts to clarify the relationship between f(x) and its inverse, as well as the reasoning behind specific values being used.
The discussion is active, with participants raising questions about assumptions made in the problem and the validity of certain steps taken. Some guidance has been offered regarding the derivative of the function and its evaluation at specific points, but there is no explicit consensus on the approach or the assumptions involved.
There is some uncertainty regarding the assumptions about the value of a and how it relates to the function. Participants are questioning the justification for certain steps taken in the problem-solving process.
BuBbLeS01
Please HELP...Differentiating Inverse Functions
f(x) = x^3 + 2x - 1 when a=2
2. The attempt at a solution
I thought you did...
1/(f '(f-1(x)))
but I am not sure how to solve for x?
0=x^3 + 2x - 1
1=x^3 + 2x -1
I tried factoring but that did not work either.
what are you looking for?
if it is f-1(a) when a = 2...
set the first equation equal to 2, which will happen when x = 1.
So, f-1(2) = 1.
Now if you want f-1'(x), you have:
= 1 / f'(f-1(x))
so 1/ f'(1)
find the derivative of f(X):
3x^2 + 2
so,
answer = 1/(3(1) +2) = 1/5.
thank you so very much!
How do you know it is 1? Because that's the only number without an X term?
How do you know f-1(2) = 1?
frasifrasi was not supposed to give away the answer, if that's the answer. That's not how this forum's supposed to work.
f -1(2) is the answer to question, "at what value of x does x^3 + 2x -1 = 2"?
frasifrasi assumed f(x) = a, which may or may not be justified. Your statement of the problem does not indicate what a is. If that assumption is right, then f -1(f(x)) = f -1(a), and by the definition of an inverse function, f -1(f(x)) = x. So x = f -1(a). You can verify that when x = 1, f(1) = 2. Therefore 1 = f -1(2).
Yea I thought it was weird that he just gave the answer. But I am trying to figure out how you figured out that x^3 + 2x - 1 = 2 when x= 1?
He solved the equation of course! Cubics can be difficult to solve so I suspect he did what I would: try some easy numbers for x and hope one works. In "real life" that is seldom true but in "made up" exercises it often is.
