More impulse and restitution >.<
  • Thread starter Thread starter BananaMan
    Impulse
The discussion revolves around a problem involving a perfectly elastic collision between two particles, P and Q, with initial speeds of 6 m/s and 0 m/s, respectively. Participants are tasked with finding the speed of Q after the impact and the impulse on Q.
  • The original poster attempts to apply the conservation of momentum and kinetic energy principles but expresses uncertainty about the coefficient of restitution. Some participants clarify that for a perfectly elastic collision, the coefficient is 1. Others provide examples of elastic collisions to aid understanding.
Participants are actively engaging with the problem, questioning the assumptions about the masses of the particles and discussing the necessary equations for solving the problem. There is a recognition of the need for complete information in the problem statement.
Some participants note the absence of mass information in the problem, which is crucial for applying the conservation laws effectively. The discussion reflects a mix of interpretations regarding the setup and parameters of the collision.
BananaMan
God i hate this damned topic >.<
Q. Two particles P and Q have speeds of 6m/s and 0m/s respectively. P directly collides with Q, the colision is perfectly elastic.
a) find the speed of Q directly after impact
b) find the impulse on Q
a)
so far i have worked out that using the law of conservation of momentum that
6 = X + 0.5Y
where x and y are the velocities of P and Q after the collision respectivly
however this is as far as i have got because to work out n e thing more i would need the coefficient of restitution
6 = E (X - Y)
b) would be easy given the velocity after :P
e=1 for perfectly elastic Collision
examples of a perfectly elastic collision (although they can never truly happen) would be a tennis ball that returns to its initial height after it is dropped or 2 billiards balls that collide and they exchange velocities. this should help get you started.
a)
6 = X + 0.5Y
6 = E (X - Y)
We would appreciate it if you would include ALL of the information in a problem (better: quote it exactly) rather than making us guess. I take it from "6= X+ 0.5Y" that P has mass 1 kg and Q has mass 0.5 kg but I don't see that information anywhere in the problem. Since this is a "perfectly elastic" collision, you also have conservation of kinetic energy (same thing: the "coefficient of restitution" is 1). Assuming P has mass 1 kg and Q has mass 1/2 kg then the total kinetic energy (1/2)(1)(62)= (1/2)(1)X2+ (1/2)(1/2)Y2 or 36= X2+ (1/2)Y2. That equation, together with X+ (1/2)Y= 6 is enough to solve for X and Y.
sorry was sleepy wen i posted it
thanks helped loads :)
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 24 ·
