Does anyone know the symbol for a vertical subset symbol Latex help
The discussion revolves around finding a vertical subset symbol in LaTeX, specifically one that points upwards and another that points downwards. Participants explore various approaches to achieve this, including the use of the rotating package for LaTeX.
  • Technical explanation, Conceptual clarification, Debate/contested, Homework-related
  • One participant inquires about a vertical subset symbol equivalent to \subseteq that points upwards and downwards.
  • Another participant suggests that the symbols for union and intersection, \cup and \cap, might be relevant, though the original poster clarifies they are not suitable.
  • The original poster explains the need for a commutative diagram using subset symbols instead of arrows, indicating the requirement for symbols that allow for equality.
  • A suggestion is made to use the rotating package in LaTeX to achieve the desired effect.
  • Further inquiry arises regarding how to implement the rotating package and whether there is a specific function for rotating symbols.
  • Links to resources are provided to assist with using the rotating package.
  • The original poster expresses difficulty in getting the rotating package to work, noting that symbols do not rotate as expected, despite no error messages appearing.
  • Another participant proposes that the issue might be related to the DVI viewer not recognizing the rotation, suggesting conversion to PS or PDF for proper viewing.
Participants do not reach a consensus on the best method to achieve the vertical subset symbol, and multiple approaches are discussed without resolution.
There are limitations regarding the functionality of the rotating package and potential viewer compatibility issues that remain unresolved.
Tzar
Does anyone know the symbol for a vertical subset symbol?? i.e the equivalent of \subseteq
but which points up (i also need one which points down)?? Thank for the help
You mean union and intersection? \cup and \cap
no no. what I am trying to achieve is like a commutative diagram but with with "subset" symbols instead of arrros. So for example, one of the ros may be A\subseteq B. I need the analogue of this but for columns. The \cup and \cap sublos won't do, for they don't have a slash next to them, indicating the possibility of equality...
Maybe you should use the rotating package for LaTeX.
How do I do that?? Is there a specific functon that allow me to rotate any given symbol??
Thank you ver much for your help..However, for some reason when I try to use the rotating package, it simply doesn't work. I type the command to rotate (after loading the package) and it simply doesn't rotate, it just prints the symbol (or any other text when I try) normally. I don't get an error message either. If comment out the line \usepackage{rotating} then I do get an error which I guess means it recognise the command \begin{rotating}...
has any ever had a similar problem?
It might be that the dvi viewer doesn't recognize what is happening.
Try to convert the dvi to ps or pdf, then view accordingly.
15K
