Thread Closed
Finding distance with a pivot
Share Thread Thread Tools
Oct18-07, 10:29 PM   #1
The two objects in the figure below are balanced on the pivot, with m = 1.8 kg. What is the distance d?
http://i241.photobucket.com/albums/f.../p13-27alt.gif
2. Relevant equations
3. The attempt at a solution
I haven't attempted a solution because I'm not sure how to set this problem up. I know that a Fnet must be found, and I know that the two masses would be in the equation and I know that the pivot would exert a normal force. I know part of the equation would be Fnet = N(pivot) - (m1 + m2)g, but where do the distances come into play?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct18-07, 10:46 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by aligass2004 View Post
Your approach will solve for the normal force at the pivot by setting Fnet=0 because the system is in translational equilibrium. But since the loads are balanced, you must also look at the rotational equilibrium about the pivot, wher the sum of the torques must be zero. Are you familiar with torque calculations for moments of the objects about the pivot point?
Oct18-07, 10:48 PM   #3
No I'm not.
Oct18-07, 11:06 PM   #4
Recognitions:
Torque of a mass about a point is just its weight times the perpendicular distance of its cg to the point. The torque of each mass must then balance. You'll have to draw a good sketch to get the proper distances involved.
Oct18-07, 11:11 PM   #5
I have no idea how to do that.
Thread Closed
Thread Tools
Similar Threads for: Finding distance with a pivot
Thread Forum Replies
Finding the distance of 2 charges Introductory Physics Homework 0
Finding distance with velocity, Uk Introductory Physics Homework 2
Finding Distance Traveled Introductory Physics Homework 5
Finding the distance to an Asteroid Astrophysics 2
Finding the charge given distance apart + some more Introductory Physics Homework 5
