SHM - mass-spring system on frictionless horizontal surface
The problem involves a mass-spring system on a frictionless horizontal surface, where a block is compressed by a force and released, leading to oscillations. The tasks include finding the spring constant, amplitude, velocity at a certain distance, and the time taken to travel that distance.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the spring constant and amplitude but encounters issues with negative values in the velocity equation. Some participants question the relationship between the starting point and the equilibrium position, particularly regarding the distance from equilibrium when the block is 30 cm from the starting point.
Participants are actively engaging with the problem, clarifying assumptions about the equilibrium position and the implications of the amplitude. There is a productive exchange of ideas, with some guidance provided regarding the relationship between distances in the system.
The original poster's calculations and assumptions about the amplitude and equilibrium position are under discussion, highlighting potential misunderstandings in the setup of the problem.
trusean
A 250 g block is resting on a frictionless horizontal surface. The block is attached to a
spring. The mass-spring system is compressed by a 2.5 N force and then released from
rest.
(a) The resulting oscillation has a 1.0 s period. What is the spring constant?
(b) What is the amplitude of the oscillation?
(c) How fast is the block moving when it is 30.0 cm from its starting point?
(d) How long does the block take to travel this distance?
T=2Pi/omega
T=2Pi*sqroot(m/k)
E=1/2mv^2 + 1/2kx^2=1/2kA^2
v=omega*sqroot(A^2-x^2)
m=mass
k=spring constant
A=amplitude
I have solved for a) the spring constant, 9.87N/m. Then I tryed to use Fs=2.5N to solve for the A by applying the equation F=-kx, where x would repersent the amplitude. This is not working out because my A=0.25m and when inputed into equation for velocity, I get a negitive value under the square root, not allowed. So I was wondering if anyone had some input on this problem. Thank you.
Realize that the starting point is not the equilibrium point. 30 cm from the starting point will bring you how far from equilibrium?
Sorry it took so long to answer. Having the amplitude equal 25cm, I am thinking it is located 25cm from the equilibrium, and thus 30cm from the starting point would be 5cm from the equilibrium?
You got it!
cool, thank you very much for your help, have a good one. And by the way, I just found this forum and I think this is a great tool for students, keep it up. peace
