Solve Torque Equilibrium to Find Tension & Force at P
  • Thread starter Thread starter ace214
    Torque
The problem involves analyzing the torque equilibrium of a uniform picture frame supported by cords, requiring the determination of tension in the cords and the horizontal force at a specific point. The subject area encompasses concepts of static equilibrium, forces, and torques.
  • Mixed
  • Participants discuss the equations of equilibrium for forces in both the x and y directions, as well as the sum of torques. There are attempts to express the relationships between tensions and forces, with some participants questioning the correctness of their torque equations and the signs used in their calculations.
Several participants are actively working through their equations, with some expressing uncertainty about their results. There is a recognition of the need to correctly account for torques and forces, and some guidance has been offered regarding the setup of equations. Multiple interpretations of the torque signs and directions are being explored.
Participants note the importance of consistent sign conventions for torques and forces, as well as the implications of the frame being stationary. The deadline for the homework is approaching, adding urgency to the discussion.
ace214
A uniform 10.0-N picture frame is supported as shown in Figure P8.62. Find the tension in the cords and the magnitude of the horizontal force at P that are required to hold the frame in the position shown.
T = Fxsintheta
So I got what's going on in each direction in a separate equation but I need another equation for the third unknown...
T1sin50 = T2
T1cos50 = F
What am I missing?
ADD: Just to fill in, the whole equations have the distances but if you use the point of gravity as your axis in each case, they are all equidistant from the axis so the distances cancel out, and the torque due to the weight of the picture ends up being 10N(0m) = 0 N*m
I'm not sure if this is correct but here goes:
Since the picture is stationary then the total upward force must equal 10.0N. Because the center of mass is in the middle and the distance to each cord is equal, we can assume that the upward force in each cord must equal 5.00N. Therefore the tension in [tex]\vec{T}_2[/tex] = 5.00N
and the tension in [tex]\vec{T}_{1,y}[/tex] in the vertical direction is 5.00N.
So to find the total tension in [tex]\vec{T}_1[/tex] we use:
5.00N / sin(50.0) = 6.53N
Then, F should be equal to [tex]\vec{T}_{1,x}[/tex] in the horizontal direction so:
F = cos(50.0) * 6.53N = 4.20N
[tex]\vec{T}_1[/tex] = 6.53N
F = 4.20N
I hope that's right
None of those are right... Seemed right to me. Any more help from anyone?
This is due 8:30 AM EST on Friday (tomorrow).
You are not doing your torque and translational equilibrium equations correctly. It's sum of forces in x direction = 0; sum of forces in y direction = 0; and sum of torques about any point = 0. That gives you 3 equations with 3 unknowns (T1, T2, and F) which you can solve. I'm not sure if you are trying to sum torques, but if you are, you have not considered the torques from all the forces.
Ok so I have:
T1sin(50) + T2 - 10N = 0
T1cos(50) - F = 0
-10N(.15m) + T1cos50(.15m) + T1sin50(.3m) = 0
Using the bottom left corner of the picture as the origin which makes the torques due to T2 and F 0 because they're on the axes.
This gave me:
T1 = 4.59796
T2 = 6.47776
F = 2.9555
None of these are right...
sigmaFy T2 + T1sin50deg = 10N
sigmaFx T1cos50deg = F
sigma M = 0 at point P
0.30T2 + 0.15T1sin50 +0.15T1cos50 -0.15(10N) = 0 [this is wrong!]
Now try to make an equation for T2 and sub it in the equation above to solve for T1.
I guess you will have to use T2 = 10-T1sin50deg.
EDIT:im getting 81.08N for T1
looks very high, so this is not a good solution i believe.
This is the correct moment equation at point P. should be.
0.30T2 +0.15T1cos50 -0.15(10N) = 0
by removing 0.15sin50, i now get 22.49N for t1.
ace214 said:
Ok so I have:
T1cos(50) - F = 0
-10N(.15m) + T1cos50(.15m) + T1sin50(.3m) = 0 the T1cos50(.15) term should be minus[/color]
This gave me:
T1 = 4.59796
T2 = 6.47776
F = 2.9555
see my note above in red..you missed a minus sign...
Why should it be minus? It's going out in the positive direction
Is my equation right then instead of poofaces? I don't understand why the torques on the axes wouldn't be 0.
ADD: you are right about the minus (I'm getting right answers now), but will you explain why?
edit:i was wrong
pooface said:
actually his T1sin50(.3) should be minus and 10(.15) should be positive.
retry that.
It works with -10(.15) -T1cos50(.15) + T1sin50(.3) = 0 as PhantomJay said.
I just don't understand why the t1cos is negative.
ADD: For completion's sake, my answers were:
T1 = 11.24478
T2 = 1.385996
F = 7.228
yea phantomjay how is the t1cos negative?? it is clockwise around the point no? same as 10N it is clockwise
EDIT I understand why now. He said that because your T1sin50 was positive although conventionally it should be negative because of its counterclockwise direction.
it doesn't matter as long as you are consistent, if you make counterclockwise positive then all clockwise must be negative.
I had the right equation and calculations but I messed up on the calculator itself.
instead of putting 1.5/0.133 for T1, I don't know why I kept putting 3/0.133. that is why i was getting double the T1, 22.49N
Good job anyways guys and thanks.
Oh... I guess I didn't fully learn the clockwise/counterclockwise thing. I was just working off an X and Y axis and the 10N was going in the -y direction. I understand now. Thanks for the help.
