Register to reply
Finding a frequency to create a given amplitude in a spring
by ViXXoR
Tags: amplitude, frequency, spring
Share this thread:
ViXXoR
#1
Oct31-07, 07:05 PM
P: 6
Damping is negligible for a 0.155 kg object hanging from a light 6.30 N/m spring. A sinusoidal force with an amplitutde of 1.70 N drives the system. At what frequency will the force make the object vibrate with an amplitude of 0.440 m?
So:
[tex]m=0.155kg[/tex]
[tex]k=6.30N/m[/tex]
[tex]F=1.70N[/tex]
[tex]A=0.440m[/tex]
2. Relevant equations
So a given equation is:
[tex]A = \frac{\frac{F}{m}}{\sqrt{\beta^2 - \beta o^2 + (\frac{b\beta}{m})^2}}[/tex]
Also:
[tex]\beta o = \sqrt{\frac{k}{m}}[/tex] so [tex]\beta o = \sqrt{\frac{6.30}{0.155}} = 40.6452 rad/s[/tex]
And:
[tex]f = \frac{\beta}{2\pi}[/tex]
3. The attempt at a solution
Damping is negligible so [tex](\frac{b\beta}{m})^2}} = 0[/tex]
Rearranging the first equation for [tex]\beta[/tex]:
[tex]\beta = \sqrt{\frac{(\frac{F}{m})^2}{A^2} + \beta o^2[/tex]
Plug in all the values:
[tex]\beta = \sqrt{\frac{(\frac{1.70}{0.155})^2}{0.440^2} + 40.6452^2}
= 47.6799 rad/s[/tex]
Now using the formula for frequency:
= \frac{47.6799}{2\pi}
= 7.5885 Hz[/tex]
It seems my answer is wrong, and I cannot find out where I am going wrong. Any advice would be greatly appreciated.
Thanks
Phys.Org News Partner Science news on Phys.org
'Smart material' chin strap harvests energy from chewing
King Richard III died painfully on battlefield
Capturing ancient Maya sites from both a rat's and a 'bat's eye view'
learningphysics
#2
Nov1-07, 01:46 AM
HW Helper
P: 4,124
You made a mistake here:
You forgot to take the square root.
ViXXoR
#3
Nov1-07, 10:41 AM
P: 6
Wow...
Thank you for pointing that out.
Hmmmmm......turns out that when I take the square root, the answer is more wrong. I'm really stumped.
learningphysics
#4
Nov1-07, 11:11 AM
HW Helper
P: 4,124
Quote Quote by ViXXoR View Post
Wow...
do you know the answer?
I get 4.095Hz. is that what you're getting?
ViXXoR
#5
Nov1-07, 11:30 AM
P: 6
Yes, that's exactly what I am getting. It is still marked as wrong though.
learningphysics
#6
Nov1-07, 11:40 AM
HW Helper
P: 4,124
And they want the answer in Hz?
ViXXoR
#7
Nov1-07, 11:43 AM
P: 6
Yes, they want the answer in Hz.
It seems they want 2 frequencies, a "Lower" one and a "Higher" one.
learningphysics
#8
Nov1-07, 11:47 AM
HW Helper
P: 4,124
Ah... I think I see the problem now... the square root shouldn't be there:
[tex]A = \frac{\frac{F}{m}}{\beta^2 - \beta o^2}[/tex]
ViXXoR
#9
Nov1-07, 11:48 AM
P: 6
If I use that equation, how will I get 2 frequencies out of it? Also, the square root is in the equation in my textbook...
learningphysics
#10
Nov1-07, 12:01 PM
HW Helper
P: 4,124
Are you sure?
The formula I'm seeing online is:
[tex]A = \frac{\frac{F}{m}}{\sqrt{(\beta^2 - \beta o^2)^2 + (\frac{b\beta}{m})^2}}[/tex]
which isn't what you had... you didn't have the extra square inside... when there's no damping... the square root and square cancel each other.
Maybe the 2 values are the plus/minus square root...
So:
[tex]\beta = +/-\sqrt{\frac{(\frac{F}{m})}{A} + \beta o^2[/tex]
[tex]\beta = +/- 8.0976 rad/s[/tex]
Frequency = +/- 1.289Hz ?
ViXXoR
#11
Nov1-07, 01:28 PM
P: 6
Awesome, you're right! One thing, can you have a negative frequency? Can I have my higher frequency at 1.289hz, and my lower one at -1.289Hz?
CaptainKamel
#12
Feb2-09, 11:33 PM
P: 1
If High frequency is:
f_high = ([tex]\beta[/tex])/(2*pi)
In order to find the low frequency:
f_low = ([tex]\beta[/tex])/(4*pi)
I got mine right that way.
Register to reply
Related Discussions
String vibration and frequency,amplitude,length Introductory Physics Homework 15
Amplitude of spring Introductory Physics Homework 1
Amplitude, frequency, and energy? Introductory Physics Homework 1
Amplitude and Frequency Introductory Physics Homework 1
Frequency - Amplitude General Physics 4
