How Do You Calculate the Radius of a Pipe in Fluid Mechanics?
The problem involves calculating the radius of a horizontal pipe through which water is flowing, given specific parameters such as viscosity, volume flow rate, and a pressure differential related to height differences in vertical tubes connected to the pipe.
  • Exploratory, Assumption checking
  • Participants discuss the interpretation of the differential pressure in the flow rate equation, questioning whether it should be treated as a height difference or as a direct pressure value.
The discussion has progressed with some participants clarifying their understanding of the pressure differential, leading to a successful resolution for one participant. However, the overall conversation reflects varying interpretations of the parameters involved.
There is a mention of a specific height difference (0.045 m) that may influence the interpretation of the pressure differential in the context of the problem.
maos
Water (n = 1.00 10-3 Pa·s) is flowing through a horizontal pipe with a volume flow rate of 0.029 m3/s. As the drawing shows, there are two vertical tubes that project from the pipe. From the data in the drawing, find the radius of the horizontal pipe.
Q = πR^4(P1-P2) / 8nL
0.029 = πR^4(0.045) / (8*10^-3 * .7)
solve for R, multiply by 100. However, i don't get the right answer...
What am i doing wrong? this seems like such a straightforward problem
Is the differential pressure, (P1 - P2), in the formula given as the head (height or depth) of water (0.045 m), or is it pressure, in which case [itex]\Delta[/itex]P = [itex]\rho[/itex]g[itex]\Delta[/itex]h, where [itex]\Delta[/itex]h is the difference in heights of the water columns, i.e. 0.045 m.
oh maybe it's pgh. let me give it a second go.
yes i got it right. thank you Astronuc for the fast reply! I owe you :)
