What is the solution to this free fall gravity question?
The discussion revolves around a free fall gravity question, specifically addressing the motion of an object thrown upwards from a height and its subsequent behavior under gravity.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the relationship between initial and final velocities in free fall, questioning the assumptions about time and height. There are inquiries about deriving equations related to an object thrown from a helicopter and how to determine its velocity upon hitting the ground.
Some participants have offered insights into the principles of motion and velocity, while others are seeking clarification on how to approach the problem of calculating distance and velocity. Multiple interpretations of the problem are being explored, particularly regarding the effects of initial velocity and height.
There are constraints related to missing information, such as the distance of the object's path and the specific parameters needed to calculate the final velocity and time of descent.
grantP
[SOLVED] Free Fall Gravity Question
question below
Vf does not equal 0, it equals -Vi.
The easiest way to look at it is that In free fall the object spends the same amount of time going up as it does going down. Also note that when the object is at the top of its path v=0.
So we know that it is in the air for 3 seconds, therefore at 1.5 seconds it is at its maximum height and v=0.
the change in velovity is 5-0=5 and the accel is 5/1.5 = 3.333m/s^2
ok thanks...on another note, how would you figure out an equation from say a helicopter which is 30m in the air and is throw up at 20m/s?
an equation to find what, the acceleration?
since i don't know the Distance of the obj.'s path (30+d) how would i go about figuring it out?
well I am looking for velocity of the obj when it hits the ground, and the time as well, and i just assumed i needed to know the distance
to do that you can use that fact that the object is moving at the same speed but opposite direction when it passes the same height on the way back down from it hieght. For example if a ball is thrown up at 5m/s when it passes the height that the thrower released it at it will be moving at 5 m/s down. So for the helicopter use the initial velocity that the ball is thrown up at in vf=vi+at
k got it
  • · Replies 30 ·
