| Thread Closed |
Temperature ? |
Share Thread | Thread Tools |
| Nov8-07, 10:34 AM | #1 |
Temperature ?
If you suspend an open-topped container of water in a pot of boiling water, water in the inner container will reach 100 degrees C but will not boil. Why is this? 2. Relevant equations 3. The attempt at a solution |
| Nov8-07, 10:52 AM | #2 |
Darned if I know! The question, as stated, makes no sense to me. The water in the open-topped container will eventually just mix with the other water, reach 100 degrees C and boil! Are there time constraints on this? Are you assuming that the heat causing the water in the pot is removed? In that case I suppose there are some conditions on the comparative size of the two containers and original temperature of the water in the container to allow the latent heat in the pot to cause an average temperature of 100 degrees for all the water but not sufficient additional heat to make up the 'heat of boiling' for all the water. But I don't think that's what's meant here.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Temperature ?
| Kelvin Temperature - Celsius Temperature Change | General Physics | 12 | ||
| Does the temperature of a body depend upon the frame of the observer? | Classical Physics | 15 | ||
| Highest possible temperature = Planck temperature? | Classical Physics | 3 | ||
| temperature | Introductory Physics Homework | 0 | ||
| Temperature change, temperature derivative of material? | General Physics | 0 | ||
