Thread Closed
[SOLVED] Change in earth's day length due to water displacement
Share Thread Thread Tools
Nov12-07, 08:59 PM   #1
About 10000km3 of water is held behind dams in reservoirs around the world. Most reservoirs are at mid-latitudes, whilst the bulk of the world's oceans are concentrated near the equator. By using conservation of angular momentum, estimate by how much the overall movement of water into reservoirs has changed the length of the day.
[The earth has mean density 5.5 x10^3 kgm-3, radius R = 6400km and radius of gyration
0.58R. The density of water is 1gcm-3, and, for the purposes of this question, the density
of sea water is not significantly different .
2. Relevant equations
i have found that radius of gyration, k has the relation k^2 = I/m
3. The attempt at a solution
i have drawn the earth and showing the reservoirs as bulges at 45 degrees from the equators just to get an idea of what is going on. I guess i need to calculate the change in moment of inertia from no reserviors to having reservoirs at these latitudes. Then seeing how this changes the radius of gyration? Any ideas?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov12-07, 10:12 PM   #2
Okay im confident that ive calculated the different moments of inertia of the before reserviors scenario and after reservoirs. So how can i calculate the difference in rotation period between these two different mometns of inertia?
Nov13-07, 12:43 AM   #3
D H
Mentor
Use conservation of angular momentum: [itex]I_-\omega_- = I_+\omega_+[/itex], where the - and + subscripts denote the before reservoirs scenario and after reservoirs scenario. The rotation period is related to the angular velocity via [itex]T=2\pi/\omega[/itex].
Nov13-07, 09:16 AM   #4
Quote by D H View Post
Brilliant, thanks for all your help guys. Out of interest, i calculated the change in the day length equals 2.07 x 10^-4 seconds shorter.
Nov13-07, 09:34 AM   #5
D H
Mentor
You're welcome. Thread marked as 'solved'.
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] Change in earth's day length due to water displacement
Thread Forum Replies
[SOLVED] Change in Water Level after throwing over anchor Introductory Physics Homework 29
How to calculate the change in R or displacement. Introductory Physics Homework 2
Earth's Wobble Blamed For Climate Change Earth 14
Reverse/change in earth's axis General Astronomy 3
Is a change in earth's surface gravity detectable? Special & General Relativity 9
