Heat required to melt an iceberg
  • Thread starter Thread starter ttk3
    Heat
The problem involves calculating the heat required to melt a portion of an iceberg, specifically 12 percent of a 1.30×105 metric-ton iceberg, while considering the phase change from ice to water at 0°C.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to apply the equation for heat transfer involving temperature change, but some participants question the appropriateness of this approach for a phase change scenario.
Participants have pointed out that the original equation used by the poster is not suitable for melting ice, emphasizing the need for the latent heat of fusion instead. There is acknowledgment of the misunderstanding, and alternative equations have been suggested.
Participants are discussing the specific heat of fusion for water and its relevance to the problem, indicating a need for clarity on phase changes versus temperature changes.
ttk3
I think I'm doing this problem correctly... I'm not sure about my change in temperature value. Any suggestions?
Icebergs in the North Atlantic present hazards to shipping, causing the length of shipping routes to increase by about 30 percent during the iceberg season. Attempts to destroy icebergs include planting explosives, bombing, torpedoing, shelling, ramming, and painting with lampblack. Suppose that direct melting of the iceberg, by placing heat sources in the ice, is tried. How much heat is required to melt 12 percent of a 1.30×105 metric-ton iceberg? One metric ton is equal to 103 kg. Assume that the iceberg is at 0°C. (Note: To appreciate the magnitude of this energy, compare your answer to the Hiroshima atomic bomb which had an energy equivalent to about 15,000 tons of TNT, representing an energy of about 6.0×1013 J.)
Q = c*m*change in temperature
Miceberg = 1.30E8 kg
12% of iceberg = 1.56E7 kg
C ice = 2.00E3
Q = 2.00E3 * 1.30E8 * 1
Q = 3.12 E 5 J
Ah... thank you
Youre using the wrong equation. Like has been stated, its a phase change and the formula would be [tex]Q = m L_{f}[/tex] where [tex]L_{f}[/tex] is the latent heat of fusion for water. IIRC its around 80 kcal/kg for water.
  • · Replies 17 ·
