QFT in a nutshell: From field to particle
The discussion revolves around understanding a specific equation from quantum field theory, particularly the expression for W(J) involving integrals and Fourier transforms. Participants are examining the transition from a spatial representation to momentum space and the implications of complex conjugates in this context.
  • Participants are attempting to manipulate the definition of W(J) and explore the role of Fourier transforms in the derivation. Questions arise regarding the presence of complex conjugates and the integration process, particularly how to handle the delta function resulting from the integration over space.
The discussion is active, with participants providing insights and corrections to each other's reasoning. Some have identified errors in their approaches, while others are clarifying the relationships between the terms involved. There is a recognition of the need to properly account for the integrals and the properties of the functions being discussed.
Participants are navigating the complexities of quantum field theory, including the definitions and properties of the functions involved. There is an emphasis on ensuring that the mathematical manipulations adhere to the definitions provided in the literature, with specific attention to the implications of real versus complex functions.
jdstokes
I don't understand how Zee gets Eq. (2) on p. 24:
[itex]W(J) = - \frac{1}{2}\int \frac{d^4k}{(2\pi)^4} J(k)^\ast\frac{1}{k^2-m^2+i\varepsilon}J(k)[/itex]
[itex]W(J) := - \frac{1}{2}\int d^4x\int d^4y J(x)D(x-y)J(y)[/itex]
I don't see where the [itex]d^4k[/itex] and factors of 2pi are coming from. Manipulating the definition of W(J) I was able to show that
[itex]W(J) = -\frac{1}{2}\int d^4 x e^{ikx}J(x)\frac{1}{k^2-m^2+i\varepsilon} J(k)[/itex]
[itex]W(J) = -\frac{1}{2}J(-k)\frac{1}{k^2-m^2+i\varepsilon} J(k)[/itex]
but this obviously doesn't agree.
Thanks.
I see you have a power E^{ikx} but I don't see a k integral... the idea is to substitute J by its Fourier transform:
[tex]J(x) = \int \frac{d^4 k}{(2\pi)^4} e^{i k x} J(k)[/tex]
and
[tex]J(y)^* = \int \frac{d^4 k'}{(2\pi)^4} e^{-i k' x} J(k')^*[/tex]
Now combine the exponentials and perform the x-integration, this will cancel out one of the k integrals
[tex]\int dx e^{i (k - k') x} = \delta(k - k')[/tex]
and then do the manipulations you did to get the [tex]\left(k^2 - m^2 + i\epsilon\right)^{-1}[/tex] and the other stuff right.
Hi CompuChip,
Thanks for replying.
Why are you taking the complex conjugate of J(x)? The definition of W(J) is
No complex conjugates there. My approach was to separate the [itex]e^{ik(x-y)}[/itex] term in the expression for the propagation D(x - y) giving
[itex]W(J) := - \frac{1}{2}\int d^4x\int d^4y J(x)\frac{e^{ik(x-y)}}{k^2-m^2+i\epsilon}J(y)[/itex]
[itex]W(J) := - \frac{1}{2}\int d^4x\int d^4y e^{ikx}J(x)\frac{1}{k^2-m^2+i\epsilon}e^{-iky}J(y)[/itex]
[itex]W(J) := - \frac{1}{2}\left(\int d^4x e^{ikx}J(x)\right)\frac{1}{k^2-m^2+i\epsilon}\left(\int d^4ye^{-iky}J(y)\right)[/itex]
[itex]W(J) := - \frac{1}{2}J(-k)\frac{1}{k^2-m^2+i\epsilon}J(k)[/itex].
Note quite right.
Omg I'm so dumb! I forgot to put the integral in the propagator. Problem solved now (I think). If J is complex, why is it [itex]J^\ast(k)[/itex] and not J(-k)?
Ah, my mistake. You get a [tex]\delta(k + k')[/tex] from the (real)space-integral hence J(k) and J(-k).
I might still be a little off here, but the general idea was as follows: J(x) is real. This implies that
[tex]J(x) = \sum_{k = -\infty}^\infty e^{ikx} J(k) <br /> \stackrel{!}{=}<br /> \sum_{k = -\infty}^\infty e^{-ikx} J(k)^* = J(x)^*[/tex]
so comparing the coefficients of the (basis) exponentials, we conclude that [tex]J(k) = J(-k)^*[/tex], therefore we can write J(k)* instead of J(-k).
  • · Replies 0 ·
