What does it mean for a series to converge on a number k?
  • Context: Undergrad
  • Thread starter Thread starter The_Z_Factor
This discussion clarifies the concept of convergence in the context of infinite series and partial sums. A series is defined as the sum of the terms of a finite sequence, while an infinite series has partial sums that approach a specific number k, known as the limit. If the sequence of partial sums converges to k, it indicates that the series has a finite limit; otherwise, it diverges. The notation used includes S_n for the n-th partial sum and the limit notation lim_{n→∞} S_n.
  • Understanding of sequences and series in mathematics
  • Familiarity with the concept of limits in calculus
  • Knowledge of notation for summation and limits
  • Basic mathematical reasoning and proof techniques
  • Study the properties of convergent and divergent series
  • Learn about the different tests for convergence, such as the Ratio Test and the Root Test
  • Explore examples of convergent series, such as geometric and p-series
  • Investigate the application of limits in real analysis
Students of mathematics, educators teaching calculus, and anyone seeking to deepen their understanding of series and convergence in mathematical analysis.
The_Z_Factor
In my book it is talking about sequences and series and such. Finite and infinite and all that, and I am confused with what it says in the book. The book says,
"If the terms of a finite sequence are added to obtain a finite sum, it is called a series. If a series is infinite, the sum up to any specified term is called a "partial sum". If the partial sums of any infinite series get closer and closer to a number k, so that by continuing the series you can make the sum as close to k as you please, then k is called the limit of the partial sums, or the limit of the infinite series. The terms are said to "converge" on k. If there is no convergence, the series is said to 'diverge'".
The bolded part is the part I don't exactly follow. What I don't get is how it says the partial sums get closer to a number k? What does it mean there. I may just be thinking about it the wrong way.
It's good to look at many books at the same time, because different books explain things differently so one thing that a book is unclear about may be very clearly explained in another. Personally, I think the dfn in your book is crap.
In any case, to answer your specific question, they are saying that the limit of the sequence of partial sum is k. You see, if
[tex]\{a_i\}_{i\in\mathbb{N}}[/tex]
is an infinite sequence, then for each positive integer n,
[tex]S_n=\sum_{i=1}^{n}a_i[/tex]
is called the n-th partial sum of the terms in the sequence. Now, {S_n} is a sequence of numbers, and it may or may not converge. By series, we mean the value of the limit of this sequence, that we note by
[tex]\lim_{n\rightarrow +\infty}S_n=\lim_{n\rightarrow +\infty}\sum_{i=1}^{n}a_i:=\sum_{i=1}^{+\infty}a_i[/tex]
  • · Replies 20 ·
  • · Replies 17 ·
