Solubility of compound in solutions other than Water
  • Thread starter Thread starter djdevine19
    Solubility Water
The discussion centers on the solubility of compounds in solvents other than water, specifically focusing on barium and silver salts. Barium carbonate (BaCO3) and barium sulfite (BaSO3) react with hydrochloric acid (HCl) to produce carbon dioxide (CO2) and sulfur dioxide (SO2), respectively, while barium sulfate (BaSO4) remains insoluble due to its stronger sulfate ion (SO4^2-) affinity. Silver chloride (AgCl) dissolves in ammonia solution due to the formation of soluble coordination complexes, whereas mercury(I) chloride (Hg2Cl2) and lead(II) chloride (PbCl2) do not exhibit similar behavior. Understanding these reactions requires knowledge of acid-base chemistry and complex ion formation.
  • Understanding of solubility rules in chemistry
  • Knowledge of acid-base reactions, particularly with HCl
  • Familiarity with coordination complexes and their formation
  • Basic concepts of gas evolution reactions in chemistry
  • Research the solubility of various salts in different solvents, focusing on non-aqueous solutions
  • Study the formation and properties of coordination complexes in inorganic chemistry
  • Explore the principles of gas evolution reactions in acid-base chemistry
  • Learn about the comparative strengths of acids and their effects on solubility
Chemistry students, educators, and anyone interested in understanding solubility behavior of compounds in non-aqueous solvents.
djdevine19
So I'm studying solubility rules and such in chemistry and everything is fine and dandy except when the solution is something other than water. Here's 2 examples that my teacher gave us that I have no idea how to do:
BaCO3, BaSO3 and BaSO4 are all slightly soluble in water. The first 2 dissolve in HCl but BaSO4 doesn't. Why?
AgCl, Hg2Cl2 and PbCl2 are all slightly soluble in water. But AgCl dissolves in ammonia solution while the other 2 dont. Why?
I understand the fact that all of these are slightly soluble in water from the solubility rules. I'm just not clear about how to approach these problems involving a solvent other than water.
Any help is appreciated!
Thanks,
David
Chemistry news on Phys.org
You have not really discussed solvents other than water. Your HCl and your ammonia, seem assumed to be in aqueous solution (meaning in water).
Barium carbonate does not quite dissolve in HCl solution; it decomposes, liberating carbon dioxide and forming Barium Chloride. I'm not sure about the sulfite - maybe something similar, liberating sulfur dioxide?
Silver salts may dissolve in ammonium hydroxide solution because the Ag+ forms coordination complexes with ammonia, and the complex is solube. The mercury and the lead also form coordination complexes with ammonia.
actually BaCO3 and BaSO3 react with the acid, to give CO2 and SO2 respectively. BaSO4 doesn't react. You may think of it like H2SO4 is a stronger acid than HCl, hence the HCl cannot displace the SO42-.
and i agree with symbolipoint about the complexes.
10K
