| Thread Closed |
[SOLVED] FBD troubles |
Share Thread | Thread Tools |
| Dec25-07, 07:32 PM | #1 |
![]() I am looking at 3-15 (with diagram). I am having trouble since there is no angle given. I have so far [itex] -F+F_{ax}+F_{cx}=0[/itex] and in y direction [itex]F_{ay}=F{cy}[/itex]. Since the y components are equal, the springs have equal unstretched lengths, can I assume that the angle they make with the horizontal must be [itex]45^\circ[/itex]? Or that since the vertical distance between the B and A must be 3 meters? Or is this not the way to be looking at it? Thanks, Casey |
| Dec25-07, 07:51 PM | #2 |
Pythagoras is the simple answer here. you can split the diagram into 2 right angled triangles with side lengths d and 3m.
| Dec25-07, 07:51 PM | #3 |
You are given enough of the sides of the triangles formed by the pulley's (d is given to you in the problem) to find the angles and other sides of the triangles. You should be able to find all the angles you need just using trig. Take another look at the figure, and try to use trig and the Pythagorean theorem to find your angles and unknown sides.
(Kurdt, you beat me to it! It was a close one though...) |
| Dec25-07, 08:44 PM | #4 |
Hint: Let be [tex]\theta[/tex] the angle that the springs make with the horizontal. Then:
[tex]\cos\theta=\frac{d}{\sqrt{d^2+9}}[/tex] Bye! |
| Dec25-07, 09:39 PM | #5 |
Thanks |
| Dec25-07, 10:55 PM | #6 |
Yes, since the two springs have the same stiffnes and the same unstretched lengths, when you apply them a force, they stretched to the same length. Therefore they form an isoceles triangle.
| Dec25-07, 11:10 PM | #7 |
I am not sure what I'm doing wrong here. The hypoteneuse=3.354m then I should have the magnitude of the spring force as [itex]F_s=-ks=-500(3.354-6)=1323 N[/itex].
Then I have in the x direction for the applied force [itex]F_A=F_s\cos\theta +F_s\cos\theta=2*1323\cos63^\circ=1.2kN[/itex] But my answer key says 158 N I got the angle from [itex]\arctan\frac{3}{1.5}=63.43^\circ[/itex] |
| Dec25-07, 11:26 PM | #8 |
[tex]F_s=500(3.345-\bold{3})[/tex]
The lenght of each spring is 3m. |
| Dec25-07, 11:32 PM | #9 |
It says in the problem statement each spring has an unstretched length of 6 m.
[itex]F_s=-ks=-k(l_f-l_o)[/itex] Where are you getting 3? Thanks for the help so far by the way. :) |
| Dec25-07, 11:40 PM | #10 |
Recognitions:
Unstretched length of each spring is 3 m. Thereforer stretching is 3.354 - 3 = 0.354m. Now calculate the force.
| Dec25-07, 11:41 PM | #11 |
But the diagram shows that each spring has an unstretched length of 3 m. Maybe the statement is ambiguous...?
Moreover, in this case: [tex]l_f>l_o[/tex] |
| Dec25-07, 11:43 PM | #12 |
OP says length of unstretched spring=6 m Thanks, |
| Dec25-07, 11:47 PM | #13 |
I'll take it up with the author! |
| Dec26-07, 12:47 AM | #14 |
Recognitions:
WHERE do you see something that says the 'unstretched spring is 3 m'??? In the quote it is given that unstretched length of AB and BC is equal to 6 m. Then ,from the diagram, obviuosly unstretche length of each spring is 3 m.
| Dec26-07, 11:21 AM | #15 |
Thanks rl.bhat. Thanks chuy. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] FBD troubles
| C++ troubles | Engineering, Comp Sci, & Technology Homework | 2 | ||
| new troubles hahah | Advanced Physics Homework | 2 | ||
| equation troubles | Precalculus Mathematics Homework | 5 | ||
| Thermodynamics troubles | General Engineering | 3 | ||
| All my Calculus Troubles | Introductory Physics Homework | 8 | ||
