Calculating Resistor Value for Driving LEDs with an NPN Transistor
The problem involves calculating the value of a resistor in a circuit where an NPN transistor drives a constant current through three white LEDs in series. The required current is specified, along with parameters such as the transistor's current gain and base-emitter voltage.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the calculation of base current and how it relates to the collector current and the resistor value. There are questions about the role of the saturation voltage and the voltage divider setup.
Some participants have offered insights into the relationship between emitter voltage and base current, while others are exploring the implications of the circuit diagram. There is an ongoing exchange of ideas regarding the interpretation of resistor values and the effects of base current on the overall circuit.
Participants note potential confusion regarding the identification of resistors in the circuit and the need to account for base current in calculations. The original poster expresses difficulty in progressing with the problem despite the guidance provided.
beesher
an npn transistor is used to drive a constant current I through three ‘white’ LEDs, connected in series. If the required current value is I = 25 mA, and the current-gain of the transistor is β = 300, find the value of the resistor R, giving your answer to 3 significant figures. You may assume for the operating conditions specified that the base-emitter voltage of the transistor is 600mV, and that its saturation voltage is 150mV.
I should point out that the base of the transistor is connected to a voltage divider, with a resistor of 10k above a resistor R.
Base Current = [tex]\frac{collector current}{gain}[/tex]
Hi guys looking for a bit of help on a past paper for my instrumentation class.
In this problem, I've tried to find the base current by dividing 25 by 300, and I'm a bit stumped as to the next step. Do i simply need to to divide the base current by the saturation voltage, or is that completely wrong?
It's been a while since working with transistor circuits, and I think I completely forget what saturation currents and voltages were, whoo
But anyways there should be some voltage going into that voltage divider, so you can figure out Vin(voltage at base) and the base current via that, and base current times gain is collector current. Since the base current depends on R, you can figure out R. There may be more nuances in there but I think that's the idea
Circuit..
Here's a circuit diagram if that can give anyone a better idea of the circuit in question.
You set the 25mA by setting the emitter voltage, because that determines the current through the emitter resistor. Ve is Vb - 600mV, so that tells you what you need for Vb. But in setting Vb, you need to account for some base current that bypasses the base resistor R.
BTW, the base resistor R and the emitter resistor "68R" cannot possibly be referring to the same "R". Does the diagram mean that the emitter resistor is 68 Ohms?
Also, keep in mind that the current through the emitter resistor is really the LED current plus the base current. Granted, 1/300 is a small number, but to be accurate (and receive full points for the answer), you need to keep track of that current.
That should be enough info to get you going again. Post up your calcs when you're done, and we'll take a look.
Cheers
Ok, thanks very much I'll get it finished tomorrow. Oh and yes the 68R is simply referring to Ohms.
Edit; Still can't figure it out :(
11K
