Where are the points?Where are the points?
The discussion focuses on calculating the electric field produced by a 10.0 nC charge located at (1.0 cm, 2.0 cm) and determining the positions where the electric field equals specific vector values. The electric field equation used is E = (1/4πε)(q/r²). For part (a), the distance from the charge is calculated to be 2 cm, which is essential for determining the radius of the circle where the electric field vectors point outward. The discussion emphasizes the importance of visualizing the electric field and applying trigonometry to find the exact positions for the given electric field vectors.
  • Understanding of electric field concepts and calculations
  • Familiarity with the equation E = (1/4πε)(q/r²)
  • Basic knowledge of trigonometry for vector components
  • Ability to apply the Pythagorean theorem in two-dimensional space
  • Study the principles of electric fields and forces in electrostatics
  • Learn how to visualize electric field lines and their directions
  • Practice solving problems involving electric field calculations with different charge configurations
  • Explore the use of vector components in physics, particularly in electric field problems
Students studying physics, particularly those focusing on electrostatics, as well as educators looking for problem-solving strategies in electric field calculations.
sam.
A 10.0 nC charge is located at position (x, y) = (1.0 cm, 2.0 cm). At what (x, y) position(s) is the electric field
a. -225,000i N/C
b. (161,000i + 80,500j) N/C
c. (28,800i + 21,600j) N/C
E = (1/4[tex]\pi[/tex][tex]\epsilon[/tex])(q/r^2)
F = Kq_1q_2/r^2
With a) I used the Pythagorean theorem to find r^2 using (x, y) which is squareroot 5. However, I'm not exactly sure where this gets me. I honestly have no clue as to where to start with this question and any help would be greatly appreciated!
I think you probably ought to show that calculation. I get for part (a) that the distance from the charge is 2 cm.
In each part, use the field magnitude to find the radius of the circle centered on the 10 nC charge on which the point could be found. You will want to make a picture of the way the field points. Since the charge is positive, the field points outward from it; where would the "test point" need to be on each circle in order to have those field vector components? (The direction can be found by the appropriate use of trigonometry.)
  • · Replies 19 ·
