| Thread Closed |
[SOLVED] Projectile Motion - Ramp Angle |
Share Thread | Thread Tools |
| Jan12-08, 07:04 PM | #1 |
Good evening everyone!
1. The problem statement, all variables and given/known data This is a classic ramp angle question. I am trying to find the angle of a ramp in order for a bus to complete the gap (Yes, this is from the film Speed, and I have searched, but haven't found a solution.) Known: Velocity = 31.29 m/s Distance of gap = 15.24 m The landing part of the road is level with the take off. 2. Relevant equations θ = (1/2) sin^-1 (fg x d / v2). 3. The attempt at a solution θ = (1/2) sin-1 (9.81 x 15.24 /31.292) θ = (1/2) sin-1 (149.5044 / 979.0641) θ = (1/2) sin-1 (0.1527) θ = (1/2) (8.7834) θ = 4.3917 degrees. This answer does not quite seem right. I have gone through my calculations, but I cannot find an error. Perhaps my equation is wrong, I am not sure. |
| Jan13-08, 11:53 AM | #2 |
I am still puzzled by this.
Could someone help me determine whether or not I am using the correct equation? |
| Jan13-08, 12:06 PM | #3 |
I see that you are using the range formula. Make sure the distance is in meters. Also remember that sin(x) = sin(180 - x), so there are two solutions for the angle that yield the same range. One of the angles is 4.39 degrees while the other angle is 85.6 degrees.
| Jan13-08, 12:09 PM | #4 |
[SOLVED] Projectile Motion - Ramp AngleI was expecting a number closer to around 25 degrees, but that was pure guessing. |
| Jan13-08, 12:12 PM | #5 |
The range equation is
[tex]R = \frac{v^2}{g}\sin{2\theta}[/tex] rearranging [tex]\sin{2\theta} = \frac{Rg}{v^2}[/tex] There are two solutions for theta [tex]\theta = \frac{1}{2} \sin^{-1}\frac{Rg}{v^2}[/tex] or [tex]\theta = \frac{1}{2}[180 - \sin^{-1}\frac{Rg}{v^2}][/tex] Plugging in all the numbers, you get [tex]\theta = 4.39^\circ[/tex] or [tex]\theta = 85.61^\circ[/tex] Any value of theta between those two will make the jump (since at either of those values, the bus barely makes it) |
| Jan13-08, 12:13 PM | #6 |
This question had me second guessing myself because we were not given the equation, I had just found it somewhere online. Cheers! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Projectile Motion - Ramp Angle
| Relativity: Projectile Motion at an Angle on Spaceship | Advanced Physics Homework | 3 | ||
| predicting a target for a ramp, using projectile motion and dynamics | Introductory Physics Homework | 0 | ||
| projectile motion - no angle given??? | Introductory Physics Homework | 2 | ||
| Deriving a Launch Angle Equation -- Projectile Motion -- Please Help | Introductory Physics Homework | 5 | ||
| projectile motion at an angle | Introductory Physics Homework | 2 | ||
