Find Source & Learn ArcTan2 for Degrees Calculation
  • Thread starter Thread starter Sky Scripter
    Function
This discussion focuses on the implementation of the ArcTan2 function for calculating angles in degrees based on Cartesian coordinates. The user seeks a source code example in a programming language and provides a specific formula: Degrees := (ArcTan2(MiddleX - X, MiddleY - Y). The ArcTan2 function is defined with conditions to handle various quadrants and edge cases, utilizing the ArcTan function for angle calculations. The provided code effectively computes the angle in degrees, ensuring results are within the range of 0 to 360 degrees.
  • Understanding of trigonometric functions, specifically ArcTan and ArcTan2
  • Familiarity with programming concepts and syntax
  • Knowledge of handling angles in degrees and radians
  • Basic understanding of Taylor series for function approximation
  • Research the mathematical derivation of the ArcTan2 function
  • Learn about Taylor series and its application in function approximation
  • Explore programming languages that support trigonometric functions, such as Python or JavaScript
  • Investigate the implementation of angle normalization techniques in various programming contexts
Mathematicians, software developers, and engineers working on graphical applications or simulations that require angle calculations based on Cartesian coordinates.
Sky Scripter
Anyone have the Source for ArcTan2 ( x, y: Extended);
I Can have it in most any programming language, if you can show me how it works.. then that would be great too.
And just so you know I am trying to calculate the Degrees in a line using ArcTan2;
for example:
Degrees := (ArcTan2(MiddleX - X, MiddleY - Y));
MiddleX := Center of the Circle (X Axis);
MiddleY := Center of the Circle (Y Axis);
X := Being the Point i want to calculate (X Axis)
Y := Being the Point i want to calculate (Y Axis)
Thanks :D
Technology news on Phys.org
I don't know what extended means, but if you want to program the arctan(x) function, you might want to use the taylor series of the function. Its the summation of [tex]\frac{x^n}{n!}f^n(x)[/tex], where [tex]f^n(x)[/tex] is the nth derivative of the function youre finding the series of.
If that's too much of a hassle, just look up the series online. In your case, replace x by y/x (as [tex]tan\theta=\frac{y}{x}[/tex] which gives [tex]\theta=tan^{-1}\frac{y}{x}[/tex].
nvm found source :)
thanks though...
Code:
function ArcTan(x: Extended): Extended;
var
  i: Integer;
begin
  if x > 1.0 then
  begin
    Result := Pi / 2 - ArcTan(1 / x);
  end else
  begin
    for i := 0 to 200 do
    begin
      Result := Result + ((Pow((-1), i) * Pow(x, (2 * i + 1))) / (2 * i + 1))
    end;
  end;
   while Result > 360 do Result := Result - 360;
   while Result < 0 do result := result + 360;
end;
function ArcTan2(y, x: Extended): Extended;
var
   A1: extended;
begin
  A1 := Pi / 180;
  if (y = 0.0) and (x < 0.0) then Result := A1 * 180;
  if (y = 0.0) and (x > 0.0) then Result := 0.0;
  if (x = 0.0) and (y < 0.0) then Result := A1 * 270;
  if (x = 0.0) and (y > 0.0) then Result := A1 * 90;
  if (Result = 0.0) and (x <> 0.0) then if (Abs(y) / Abs(x) = 1.0) then
    begin
      if (y > 0.0) and (x > 0.0) then Result := A1 * 45;
      if (y > 0.0) and (x < 0.0) then Result := A1 * 135.0;
      if (y < 0.0) and (x < 0.0) then Result := A1 * 225.0;
      if (y < 0.0) and (x > 0.0) then Result := A1 * 315.0;
    end;
  if Result = 0 then
  begin
    Result := ArcTan(Abs(-y) / Abs(x));
    if (y > 0.0) and (x < 0.0) then Result := Result + A1 * 90.0;
    if (y < 0.0) and (x < 0.0) then Result := Result + A1 * 180.0;
    if (y < 0.0) and (x > 0.0) then Result := Result + A1 * 270.0;
  end;
end;
