Is This Trigonometric Identity Solvable?
The discussion revolves around proving a trigonometric identity involving tangent and sine functions. Participants are exploring the manipulation of trigonometric expressions to simplify and verify the identity.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss converting tangent to sine and cosine, simplifying expressions, and the implications of multiplying by certain terms. Questions arise about the validity of specific algebraic manipulations and the meaning of terms like "LHS."
There is an ongoing exchange of ideas, with some participants providing guidance on how to approach the problem. Multiple interpretations of the steps involved are being explored, and while some participants express confusion, others attempt to clarify the process.
Participants mention having extensive attempts documented, indicating a challenging problem. There is also a reference to homework constraints, suggesting that the discussion is framed within an educational context.
krogsty
[SOLVED] Proving Trig Identities
Prove that
tanx - sinx---=---- tanxsinx
________------- _________
tanxsinx -------- tanx + sinx
Is this impossible, so far it has been for me, what about you?
I litterlly have 4 pages of written of attempts, I just can't figure it out
Actually it isn't that hard.
I used the LHS and just simply converted all the tanx to sinx/cosx and simplified it. Did you do that?
What does LHS stand for?, and I have converted the tanx's to sinx/cosx, but there are so many ways to go from there, I just can't seem to get one, Can you possibly tell me the final simplified version of either side that you got?
LHS is Left Hand Side.
[tex]\frac{tanx-sinx}{tanxsinx}= \frac{\frac{sinx}{cosx}-sinx}{\frac{sin^2x}{cosx}}[/tex]
then multiply the numerator and denominator by cosx then what do you get?
And always remember that [itex]sin^2 x+cos^2 x=1[/itex]
Am I aloud to multiply the sinx/cosx before finding common denominators with -sinx?
[tex]\frac{\{sinx-sinxcosx}{cosx}[/tex]
Is this what you mean?
[tex]\frac{\sinx-sinxcosx}{cosx}[/tex]
Well if you multiply the Numerator and denominator by cos x then it is the same as multiplying by 1. So that it remains the same.
But you were supposed to get [tex]\frac{\{sinx-sinxcosx}{sin^2 x}[/tex]then recall that [itex]sin^2 x=1-cos^2 x[/itex]
So I'm suppose to reduce the left side to
and then do that to the right?
No. Work with one side only. After you reduce it to what is above. Just substitute sin^2x and you will get the answer in another 4 lines
I'm sorry, I don't follow any of this, Normally I understand this stuff, but this "puzzle" is just confusing me
[tex]\frac{\frac{sinx}{cosx}-\frac{sinxcosx}{cosx}}{\frac{sinx^{2}}{cosx}}[/tex]
Using the LHS
[tex]\frac{tanx-sinx}{tanxsinx}[/tex]
sub [itex]tanx=\frac{sinx}{cosx}[/itex]
[tex]\frac{\frac{sinx}{cosx}-sinx}{\frac{sin^2x}{cosx}}[/tex]
multiply both the numerator and denominator by cosx
[tex]\frac{cosx (\frac{sinx}{cosx}-sinx)}{(\frac{sin^2x}{cosx})cosx}[/tex]
[tex]\frac{sinx-sinxcosx}{sin^2x}}[/tex]
sub [itex]sin^2x=1-cos^2x[/itex]
Following better now?
Then I want to get
[tex]\frac{sinx(1-cosx)}{(1+cosx)(1-cosx)}[/tex]
correct?
krogsty said:
Then I want to get
correct?
yes, what do you have left now when the 1-cosx cancels out?
you get
[tex]\frac{sinx}{1+cosx}[/tex] Then I reduce the right side to the same thing, right?
krogsty said:
you get
Nope. you need to somehow make the Left side the same as the right side. Which is what you are doing
What you want is
to somehow become
[tex]\frac{tanxsinx}{tanx+sinx}[/tex]
Now if you take what you have and multiply the numerator and denominator by tanx
the numerator will become tanxsinx right? Isn't that the numerator that you want?
Deal with the denominator now.
(1+cosx)(tanx)---------------tanx + cosxtanx---------------tanx + cosxsinx/cosx
cancel out the cosx and you get tanx + sinx
Yes, the denominator is now tanx+sinx and the numerator is tanxsinx
so you now have what they wanted...
Thank you so much for your help, You were the 3rd person I asked, and the only one who actually knew how to solve this, you are the man, thanks again.
