| Thread Closed |
Kinetic energy of inelastic collision problem |
Share Thread | Thread Tools |
| Jan21-08, 06:28 PM | #1 |
A particle of mass m1 and velocity u1 collides with a particle of mass m2 at rest. The two particles stick together. What fraction of the original kinetic energy is lost in the collision? 2. Relevant equations Conservation of momentum law 3. The attempt at a solution I think this one is right but was hoping somebody could check for me... It seemed too easy, so I just wanted to make sure I'm understanding it correctly. m1u1 = (m1 + m2)u by conservation of momentum, so u = m1u1/(m1+m2) Ti = ½ m u1^2 and Tf = ½ (m1+m2)u^2 = m1^2 u1^2/2(m1+m2) in terms of u1 Then I found Ti – Tf = (m1m2 u1^2)/2(m1 + m2) and then found ratio of this with Ti I got m2/(m1 + m2). Is this correct? Thanks!!! :) |
| Jan21-08, 06:46 PM | #2 |
Recognitions:
I got [itex]\frac{m_1}{m_1+ m_2}[/itex] and worked it the same basic way you did.
| Jan21-08, 07:35 PM | #3 |
Mentor
At least one of you two is obviously wrong. How much energy is lost when you throw a 1 gram spitball at a 75 kg man? What happens when a 75 kg man runs into a 1 gram spitball suspended from the ceiling?
| Jan24-08, 12:19 AM | #4 |
Hi, rock.freak667, isn't your answer the amount of the original remaining (not lost)? I'm not sure, I'll check my work again. Man's kinetic energy isn't effected much but spitball's is - I think that's what makes me uncomfortable about these problem w/o numbers - harder to get an intuitive feel for them but making up concrete examples helps. Thanks to both of you.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Kinetic energy of inelastic collision problem
| Kinetic Energy and Inelastic Collisions | General Physics | 50 | ||
| [SOLVED] Elastic Collision/Kinetic Energy Problem | Introductory Physics Homework | 4 | ||
| Inelastic collision energy relationship | Introductory Physics Homework | 6 | ||
| Inelastic collision and conservation of energy | Introductory Physics Homework | 2 | ||
| need help with an inelastic collision problem | Introductory Physics Homework | 1 | ||
