What is the purpose of an inversion layer in a MOS device?
  • Context: Graduate
  • Thread starter Thread starter Theraven1982
    Inversion
The discussion revolves around the purpose and function of the inversion layer in MOS (Metal-Oxide-Semiconductor) devices, particularly in the context of charge-coupled devices (CCDs). Participants explore the mechanisms behind the formation of the inversion layer and its significance in device operation.
  • One participant questions why electrons form an inversion layer when a positive voltage is applied, seeking to understand the significance of the Fermi energy level being above the intrinsic energy level.
  • Another participant states that the inversion layer is necessary to establish a conducting channel for majority carriers to move easily.
  • A different participant challenges the necessity of the conducting channel, noting that the inversion layer is above the depletion region and questioning its role when charges move from well to well during device operation.
  • One participant corrects a previous statement, indicating that the inversion layer provides minority carriers rather than majority carriers.
  • A participant references the Fowler-Nordheim theory in relation to a formula for calculating dark current, suggesting that the derivation involves many simplifications and assumptions.
Participants express differing views on the necessity and role of the inversion layer in MOS devices, with no consensus reached on its function or the implications of its presence.
Some claims about the roles of majority and minority carriers remain unresolved, and the discussion includes varying interpretations of the inversion layer's significance in the context of charge movement within the device.
Theraven1982
[SOLVED] inversion layer in a MOS
Hello,
I have some questions about MOS devices, and CCD
In a MOS or MIS after applying a voltage on the metal, the valenceband and the conduction band bend downwards (in the usual band diagram) when a positive voltage is applied. (p-type semiconductor).
When the voltage is large enough, the fermi energy (in equilibrium) is above the intrinsic energy level, so that an inversion charge will build up.
The first thing I don't understand is why the electrons make an inversion layer in the first place. I mean, why would the electrons come so close to the oxide/semiconductor boundary in the first place (I understand the electrons are drawn to this boundary by the applied voltage, but why is it such a big deal that the Fermi energy level is larger than the intrinsic level?)
The second thing I don't understand, is what is the use of this inversion layer? Why is the inversion layer necessary in a CCD?
Any help would be greatly appreciated,
thanks in advance,
Oh, and a bonus 'question': I've seen a useful formula for calculating the dark current, but I can't find a reference. It's about this formula:
amount of dark current generated = [tex]CT^{1.5}e^{-E_g/2kT}[/tex]
I've seen it in some books, but none of them make a reference to where it is derived, and I don't have a clue how to derive it myself.
(Maybe this question isn't in the right place here, then I'll try a different subforum).
Look into the Fowler-Nordheim theory for field emission current. The derivation to get that particular equation isn't trivial and makes many simplifications and assumptions.
Zz.
Thanks a lot for your answer.
It is not necessary that I know exactly how it is derived, but just wanted to know where it came from. I've seen the name 'Fowler-Nordheim' before in a paper, and now I at least understand where it comes from.
Any takers for the other questions? ;)
The inversion layer is necessary to establish a conducting channel through which majority carriers can easily move.
- Warren
Thanks.
But why is this conducting channel needed? This inversion layer is above the depletion region which fills up with charge; when the device is clocked (for measuring how much charge is in the well), the charges move from well to well. I don't see the need for this conducting channel.
Theraven1982 said:
Thanks.
The inversion layer provides the majority carriers (electrons or protons in nMOS and pMOS case) which make up the current. The inversion layer IS the conducting layer
marlon
The inversion layer provides the MINORITY carriers not the majority carriers.
My mistake.
marlon
I'm sorry for the (very) late reply, but thanks a lot! I now fully understand. Sometimes I need to ripen new information ;).
Thanks again all!
9K
