| Thread Closed |
Acidic Water Molecules |
Share Thread | Thread Tools |
| Jan30-08, 05:25 PM | #1 |
Given the following article:
http://www.innovations-report.de/htm...cht-96564.html What are "acidic water molecules"? |
| Jan30-08, 08:50 PM | #2 |
I just went looking in wiki for pH and they talk about H3O+ as a sort of substitute for H, so maybe that's what they're talking about. |
| Jan30-08, 11:07 PM | #3 |
Recognitions:
H_3 O^{ + 1} \] [/tex], represents both an ion and a solvated proton; not a molecule |
| Jan31-08, 03:16 AM | #4 |
What makes things acidic is H+ ions, right?
That's only correct to a certain extent. When we refer to H+ ions, we refer to the hydronium ion, H3O+ as some have said. This is what makes acidity. You can't have acidity without water. So you can have the most intense acid in the world, with a pH of 1 or something, but if you remove the water content from it, it will not be acidic. |
| Jan31-08, 07:56 AM | #5 |
Just what the authors of the innovations report mean by acidic
water is not clear to me. To see one example of how the phrase "acidic water molecules" is actually used by chemists, go to http://www.rsc.org/ej/CC/2001/b103533a.pdf Toward the end of the article you read: "...When phenylboronic acid is then added to the methanol solution water molecules present in the methanol coordinate with the boron Lewis acid and become more acidic. These more acidic water molecules can now protonate compounds 1 and 3 as well as compound 2." So, acidic water molecules are simply molecules of water that can more easily give up a proton. Note that water is not necessary to have an acid. An acid is a substance that can take up an electron pair to form a covalent bond. For example, boron trichloride (BF3) is an acid and combines with such bases as ammonia or ethyl ether. |
| Jan31-08, 08:23 AM | #6 |
| Jan31-08, 08:25 AM | #7 |
| Jan31-08, 11:26 AM | #8 |
By far the most abundant interstellar polyatomic molecule aside from H2 is H3+. Since the proton affinity of H2 is extremely low, this abundant molecular ion is a strong acid and will protonate anything it comes across, including water. This produces the ion H3O+ which has a characteristic far infrared spectrum that can be observed with the proper equipment. This is what is meant by interstellar acidic water.
Here is a paper on the subject. |
| Jan31-08, 11:31 AM | #9 |
Of course, this is nothing compared to the strength of superacids. Search "George Olah" for more information on that subject. |
| Jan31-08, 03:02 PM | #10 |
| Jan31-08, 04:01 PM | #11 |
If you don't mind all the heavy metals!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Acidic Water Molecules
| What causes the H bonds in water molecules to last only 10^-11 sec? | Biology, Chemistry & Other Homework | 1 | ||
| does water molecules exist in KOH(aq)? | Biology, Chemistry & Other Homework | 1 | ||
| Oceans becoming more acidic | Earth | 4 | ||
| Figuring out the acidic % of a certain food | Chemistry | 7 | ||
| Basic, Acidic, or Neutral | Chemistry | 21 | ||
