Solving Resistor Circuits: Tips & Tricks
  • Thread starter Thread starter BuBbLeS01
    Test Urgent
The discussion revolves around calculating current in a circuit with two batteries and multiple resistors. The original poster expresses difficulty in approaching the problem, which is from their textbook and cannot be shared visually.
  • Participants suggest using equivalent resistors for blocks in parallel and series, and applying Kirchhoff's laws. The original poster questions how to determine the current through individual resistors after calculating the current through an equivalent resistor.
Some participants have offered general guidance on using Kirchhoff's laws and equivalent resistors, while others express concern about the urgency of the original poster's situation. The discussion is ongoing with various interpretations and approaches being explored.
The original poster is under time pressure due to an upcoming test and has not provided specific details about the circuit configuration, which may limit the guidance offered.
BuBbLeS01
Urgent...test In 58 Minutes!
I am having a hard time figuring out how to calculate the current in a circuit consisting of 2 batteries and numerous resistors. Unfortunautely the problem I am trying to do is in my book so I can't post a picture. But if someone can give me a general idea of how to approach these kinds of problems I would greatly appreaciate it!
Replace blocks of resistors in paralle with a single equivalent resistor.
Remember that voltage drops across each resistor in a circuit must add up to the battery voltage.
current through all resistors in series must bee the same.
have you learned kirchhoffs laws before? learning your concepts right before your exam is not good.
It's kind of difficult to help you if you haven't posted a specific problem. But you only need to use Kirchoff's voltage law and Kirchoff's current law here. Remember that the potential difference across a resistor is simply V = IR. Start by labeling currents in the circuit as I1, I2, I3 etc.
Well, that's all I can say without any more input from you.
EDIT: To mgb_phys advice I would add that you should always replace resistors in series with equivalent resistors. Kinda obvious I know.
This is a little off-track but it seems like you're panicking over something which you probably know how to do outside of exams. Have a look through your tutorials to refresh your memory.
I redrew the picture with 2 batteries 1 on each side and 2 resistors 1 on top and 1 bottom. Now that I calculated the current through the top resistor how do I work backwards to calculate the current through the each individual resistors that make up that equivalent resistor? Does that make sense?
I ended up with having a 12 V bat on the left side of the circuit then a 24 Ohm Resistor on the top, a 3 V bat on the right and a 3 Ohm Resistor on the bottom. Also how do I know which bat to use to calculate the current?
  • · Replies 62 ·
