| Thread Closed |
[SOLVED] Parametric equation of the intersection between surfaces |
Share Thread | Thread Tools |
| Feb15-08, 03:26 AM | #1 |
Given the following surfaces: S: z = x^2 + y^2 T: z = 1 - y^2 Find a parametric equation of the curve representing the intersection of S and T. 2. Relevant equations N/A 3. The attempt at a solution The intersection will be: x^2 + y^2 = 1 - y^2 x = (1 - 2y^2)^0.5 At this point, I plug in the following parametrization: y = sin(t) Which yields: x = (1 - 2(sin(t))^2)^0.5 y = sin(t) z = 1-(sin(t))^2 (from the equation for T) with t = 0..2*Pi. Judging from a Maple plot this seems to make sense; the curve is a projected ellipse, but due to the x term I have to split it into two separate segments. I'm pretty sure I should be able to use a more elegant solution with a single curve, but I haven't been able to figure it out - any help would be welcome. Thanks- |
| Feb15-08, 05:34 AM | #2 |
In a situation like that it is better not to solve for one of the variables.
Instead, change x2+ y2= 1- y2 to x2+ 2y2= 1, the equation of an ellipse. Then use the "standard" parameterization of an ellipse: x= cos(t), y= sin(t)/[itex]\sqrt{2}[/itex]. Then, of course, you can have either [itex]z= cos^2(t)+ (1/2)sin^2(t)[/itex] or [itex]z= 1- (1/2)sin^2(t)[/itex]. |
| Feb15-08, 09:30 AM | #3 |
Great, thank you.
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Parametric equation of the intersection between surfaces
| Intersection of surfaces | Calculus | 5 | ||
| Intersection between surfaces | Calculus & Beyond Homework | 2 | ||
| curve of intersection between surfaces | Calculus & Beyond Homework | 1 | ||
| Intersection of surfaces/tangent vector | Introductory Physics Homework | 1 | ||
| [SOLVED] Parametric Surfaces and Their Areas | Calculus | 4 | ||
