Understanding Spring Stretch in Hooke's Law
The discussion revolves around the application of Hooke's Law in understanding how a spring stretches when a weight is applied. The original poster presents a scenario involving a spring constant and a mass, leading to confusion regarding the sign of the displacement.
  • Participants explore the implications of coordinate systems on the interpretation of displacement, with some suggesting that the negative sign in the displacement indicates direction rather than an error in calculation.
Participants have engaged in clarifying the role of coordinate systems in determining the sign of displacement. There is an acknowledgment that the negative sign reflects directionality, and the discussion appears to be productive in addressing the original poster's confusion.
There is an ongoing examination of how different definitions of positive and negative directions can affect the interpretation of spring displacement in the context of Hooke's Law.
torresmido
A spring with spring constant k=340 N/m is used to weigh a 6.7 KG fish. How does the spring stretch?
I used Hooke's law (F=-Kx), but ended up having a negtive distance x=-0.2m. Is this expected? in the problem they say the spring stretches...this is confusing me...thank you for your help guys in solving this problem
I think it depends on how you define your coordinate system. Say downward is the negative direction and the spring at equilibrium is at x=0. Then when you add the weight the spring stretches downward and x is at some negative value, so [tex]\Delta x[/tex] is negative. Force on the weight is opposite the displacement in the positive direction.
On the other hand, if you choose up to be the negative direction, then your change in x is positive and the force on the weight is in the negative direction.
Either way, the spring stretches the same distance, the negative sign would just tell you which direction the end of the spring moves (and whether negative is up or down depends on your coordinate system)
fs =-kx
During compression delta x is negative.
you are correct.negative sign just indicates the direction of motion of spring.
Thanks guys! this was so helpful
  • · Replies 35 ·
  • · Replies 17 ·
  • · Replies 20 ·
