Calorimetry- how do I know the final temperature?
The discussion centers on conducting a calorimetry experiment to determine the mass of a hot metal submerged in water. The key to identifying the final temperature of the water-metal mixture lies in recognizing when thermal equilibrium is achieved, despite potential heat loss to the surroundings. Participants concluded that the highest recorded temperature before any decline should be considered the final temperature. Additionally, the conversation addressed the importance of controlled variables in the experiment, emphasizing consistent temperature measurement methods.
  • Understanding of calorimetry principles and thermal equilibrium
  • Knowledge of heat capacity for both water and metal
  • Familiarity with controlled and manipulated variables in experimental design
  • Basic mathematical skills for solving calorimetry equations
  • Research the concept of thermal equilibrium in calorimetry
  • Learn how to calculate heat transfer using the formula -mct = mct
  • Explore methods for minimizing heat loss in calorimetry experiments
  • Investigate the role of controlled variables in scientific experiments
This discussion is beneficial for students conducting calorimetry experiments, educators teaching physics or chemistry, and anyone interested in understanding heat transfer and thermal dynamics in laboratory settings.
jumbogala
I am doing a lab in which I have to come up with my own procedure. The lab involves putting a hot metal into water, then using calorimetry calculations to find the mass of the metal. (The metal is hotter than the water).
What I don't understand is how you know when to stop taking the final temperature of the water + metal mixture. I would assume it's when the mixture has reached thermal equlibrium. But at that point won't the whole mixture lose heat to the surroundings because the calorimeter isn't perfect?
So how do I know when it's reached thermal equilibrium if it will always be losing heat to the surroundings?
Also on the list of materials, it says "reggae". Nothing in the dictionary besides reggae music. Any ideas?
Assume that the calorimeter is perfect. The water will initially be cold and slowly warm up until the temperature changes no more. What will be that temperature if you know the heat capacity of the water and the metal and their respective temperatures before the experiment?
The reggae is probably there as a joke... Turn on some music.
After the temperature stops rising, it will start to fall, I guess. So the highest recorded temperature would be the final temperature... right? So you would have -mct = mct, solving for m. I think I get it, thanks!
Also our teacher wants us to include variables. I understand that controlled variables will be things like measuring the temperature of the water the same way each time, etc.
But since this is an experiment that deals with calculations, couldn't the manipulated variable be different each time? And I wouldn't think there would be a responding variable since the mass of the metal doesn't ever change.
Am I right about that or are there variables that I'm missing?
