Where is the neutral point? Electrostatics
The discussion revolves around finding the neutral point in a system of two point charges, specifically a positive charge of +2nC and a negative charge of -3nC, separated by a distance of 2.0m. The participants are exploring the conditions under which the electric field intensity is zero.
  • Participants discuss the distances d1 and d2 from each charge to the neutral point, with some suggesting a one-dimensional approach to visualize the problem. There is mention of the neutral point not being located between the two charges, prompting questions about the reasoning behind this assertion.
The conversation is ongoing, with participants sharing insights about the setup and the implications of charge interactions. Some have offered guidance on visualizing the problem and the relationships between the distances, while others express confusion and seek clarification on specific points.
There is a suggestion that there may be two neutral points, leading to a quadratic equation, although this has not been fully explored. Participants are also questioning the implications of charge attraction and repulsion in determining the location of the neutral point.
rize
At the neutral point the electric field intensity is zero. Two point charges q1=+2nC and q2=-3nC are separated by 2.0m in air. Where is the neutral point?
E=f/q
coloumbs law
E=E[q1] + E[q2]
i don't have a solution for now since i can't figure out how to solve for d1 and d2
What are [tex]d_1[/tex] and [tex]d_2[/tex] ??
d1 is the distance of q1 from the neutral point , d2 is the distance of q2 from the neutral point
Just try to look at it like a 1D problem. Along a line joining the two charges there will be a point where the sum of the fields is 0. Also using rules of repulsion/attraction for charges, you can figure out that the point will NOT be between the two charges. So the distance from one charge is d1, and the distance from the second charge is 2+d1.
Drawing a picture always helps. :)
Just take it as 'd' from q1. Once you calculate distance from q1, you can use your math to get the distance from q2.
Actually, in this case there will be two neutral points. So you'll get a quadratic equation.
Code:
           *                 q1-------------------------------q2          *
Code:
                   d
* is neutral point.
[tex]E_{q1}=E_{q2}[/tex]
[tex]\frac{k*2}{d^2}=\frac{k*3}{d+2}[/tex] <-----------------solve this.
how can it happen that it won't be between the charges?
https://www.physicsforums.com/latex_images/16/1629068-1.png
why is it d+2.. ? where did the 2 come from?
still need answer to this :( thanks to those who can help
Just use your rules of repulsion/attraction between two charges. If the test change was placed between the two charges in the question, The negative would attract it left and the positive would push it away, towards the left. No matter how you add them, it would result in a vector pointing left.
The 2 is the distance between the 2 charges. As I said earlier in my post, a diagram always helps, the red dot is the neutral point.
http://img87.imageshack.us/img87/2843/80141767hn2.th.png
  • · Replies 69 ·
