Complex Solutions Homework - Find Zeros of Equation
  • Thread starter Thread starter Firepanda
    Complex
The discussion revolves around finding the zeros of a complex equation, specifically focusing on a quadratic equation with complex coefficients. Participants are exploring the nature of the roots and the implications of complex conjugates in this context.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Some participants attempt to find one zero of the equation and suggest using its conjugate as the other zero, while others question the validity of this approach given the nature of the coefficients. There is mention of using the quadratic formula and calculating the square root of a complex number.
The discussion is ongoing, with participants providing different perspectives on the problem. Some guidance has been offered regarding the use of the quadratic formula and the need to calculate complex square roots, but there is no consensus on the correct approach yet.
Participants highlight that the roots of a quadratic equation are conjugates only if the coefficients are real, which raises questions about the assumptions made in the original setup. There is also a discussion about the implications of having complex numbers in the coefficients and the resulting calculations.
Firepanda
http://img238.imageshack.us/img238/1381/complexle5.jpg
I figure if i just find 1 zero of the equation i can use its conjugate as the other zero, then I guess it's complete.
I know this:
where a is an element of C (Complex)
(z - a) (z - a(conj)) = z^2 - 2(Re a)z + |a|^2
so.. using this
2(Re a) = 1 + 3i
and
|a|^2 = -1 + 3i/4
But what to do from here?
Hmm perhaps I have to find the discriminant:
which is -4 + 3i
so z = (-(1 + 3i) +- i(sqrt (4 - 3i)))/2
:/ doesn't look too correct
quadratic equation …
This is an ordinary quadratic equation.
Just solve it the ordinary way. :smile:
(The only difficulty is that you'll have to calculate the square root of a complex number.)
No, that's not true. The two roots of a quadratic equation must be conjugates only if the equation has all real coefficients.
I know this:
so.. using this
2(Re a) = 1 + 3i
but that's impossible: 2(Re a) must be a real number.
Again, the roots of this equation are not complex conjugates.
and
|a|^2 = -1 + 3i/4
Once more, that's impossible. |a| is a real number, its square is a real number.
Use the quadratic formula or complete the square.
  • · Replies 20 ·
