Prove limit of improper Integral is 1
The problem involves evaluating the limit of an improper integral as \( n \) approaches infinity, specifically showing that \(\lim_{n \to \infty}(\frac{1}{n!}\int_{1}^{\infty}x^n\frac{1}{e^x} dx )=1\). The context is within the study of improper integrals and limits in calculus.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of integration by parts to evaluate the improper integral and express concerns about the behavior of the resulting terms as \( b \) approaches infinity. There are questions about the inclusion of the factorial term and how it affects the limit. Some participants are exploring the potential for summing parts of the integration process.
The discussion is ongoing, with participants providing hints and suggestions for further exploration. There is no clear consensus yet, as various interpretations and approaches are being considered, including the potential for repeated integration by parts and the implications of the factorial in the limit.
Participants are navigating the complexities of improper integrals and limits, with some expressing uncertainty about the convergence of the integral and the role of the factorial in the limit process. There is a hint that the problem may relate to the series expansion of \( e \).
sinClair
Show [tex]\mathop{\lim}\limits_{n \to \infty}(\frac{1}{n!}\int_{1}^{\infty}x^n\frac{1}{e^x} dx )=1[/tex]
The hint is that [tex]e=\mathop{\lim}\limits_{n \to \infty}\sum_{k=0}^{n}1/k![/tex]
First I wrote out the improper integral as limit of a proper integral. Then I tried to integrate by parts with u=x^n dv=e^-xdx...which eventually gets that proper integral to be [tex]1/e-b^n/e^b+n\int_{1}^{b}\frac{1}{e^x}x^(n-1)dx[/tex]
But even when I take limit b->infinity of this remaining integral either it's going to exist and be finite in which case when i take n->infinity it will be infinite or else it dosn't exist or is not finite in which case the original integral is not improperly integral. I tried using u=e^-x and dv=x^n with little success as well--did I make a mistake somewhere here?
Thanks.
sinClair said:
[tex]1/e-b^n/e^b+n\int_{1}^{b}\frac{1}{e^x}x^(n-1)dx[/tex].
Hi sinClair! :smile:
You haven't included the 1/n! :
[tex]\frac{1/e-b^n/e^b}{n!}\,+\,\int_{1}^{b}\frac{x^{n-1}\,e^{-x}}{(n-1)!}dx[/tex]​
… and then you can keep doing it again … :smile:
Are you thinking that you just keep on integrating by parts and then that will yield a sum that will be e? I'm having trouble summing up the uv part of the integration... I mean when i do it again I get -b^n*e^-b+e^-1+n(-e^-b*b^n-1+e^-1+integral...) this sums up...?
I haven't actually cheked it, but from:
don't you eventually get something like
[tex]e^{-1}\sum\frac{1}{n!}\,-\,e^{-b}\sum\frac{b^n}{n!}[/tex]​
? :smile:
