Tetanus Prevention Injection: Why Did Nurse Plug Plunger Back?
  • Context: Medical
  • Thread starter Thread starter rohanprabhu
    Injection
The discussion centers around the procedure of administering a tetanus-prevention injection, specifically the practice of pulling back the plunger to check for blood return in the syringe. Participants explore the reasons behind this action and its implications for intramuscular (IM) versus intravenous (IV) injections.
  • One participant questions why the nurse pulled back the plunger after inserting the needle, suggesting it might be to ensure the injection was not into a blood vessel.
  • Another participant notes that pulling back the plunger is typically done for IV injections, expressing confusion about its necessity for an IM injection.
  • A later reply clarifies that pulling back slightly during an IM injection can indicate whether the needle is in a vein or artery, with minimal blood return suggesting the needle is correctly placed in muscle tissue.
  • One participant asks if this practice implies that substances intended for IM injection cannot be safely injected into a major blood vessel.
  • Responses indicate that the IM route is chosen to allow for a slower absorption of the drug, and that injecting directly into the bloodstream could lead to undesired effects.
  • Another participant emphasizes that the safety of injecting certain substances directly into the bloodstream depends on the specific medication, noting that vaccines are designed to remain localized to elicit an immune response.
  • Concerns are raised about the variability in anatomy, suggesting that checking for blood return is necessary to avoid injecting into a blood vessel.
Participants express varying levels of understanding and agreement regarding the reasons for pulling back the plunger during an IM injection. While some clarify the rationale behind the practice, others remain uncertain about the implications for different types of injections, indicating that multiple competing views remain.
There are limitations in the discussion regarding the specific substances being injected and the potential effects of injecting them into the bloodstream versus muscle tissue. The discussion also reflects a dependence on individual training and experience levels among participants.
This discussion may be of interest to individuals studying nursing, emergency medical services, or anyone curious about vaccination procedures and injection techniques.
rohanprabhu
recently i got a tetanus-prevention injection.. and i noticed that the nurse after piercing the needle, plugged the plunger back and took some blood inside the syringe [very little].. like 1/10th the solution in it and then pushed the plunger back. My question is.. why did she do that? My first guess was that she was making sure that it is being injected into a blood vessel.. but i have no idea about biology.. so i thought i'd ask it here.
Biology news on Phys.org
That's why it's done for an intravenous injection. All of my tetanus shots, however, were intramuscular. I'm not sure why she would do it for that. :confused:
No, she was making sure that the needle was not in a vein or artery. For IM injections, you can pull back slightly to be sure you don't get an easy flow of blood (which you would if you were in an artery or vein). If not much blood draws back, that means you are IM and just getting a bit of capillary blood.
Ah, that makes sense. So does this imply that something normally used as an IM injection can't be safely put into a major vessel?
That question goes a bit beyond my training (EMT). The IM route is chosen to lengthen the amount of time it takes for the drug to enter the bloodstream. If it hits the bloodstream all at once, it would seem that the desired effects may not occur correctly, and side effects could be aggrevated. It would take a paramedic, nurse or a doc to give a knowledgeable answer, though.
I was totally unaware of that reason for IM. Thanks muchly for the info.
It depends on what is being injected as to whether it would be safe to go directly into the blood stream. Sometimes that is the case. In the case of a vaccination, you want the vaccine to stay in one place long enough to develop an appropriate response to the vaccine so you develop the immunity. In the case of some other drugs, both routes are safe, but an injection IM will provide slower delivery of the drug to circulation than IV...if you want a quick action, but rapid clearance, IV is desired. If you want a slower, more constant release, IM or subcutaneous (SC) are desired.
If you see blood when you draw back on a syringe for an IM injection, you should move the needle so you don't inject it into the bloodstream directly. There's a lot of variation in the location of veins and arteries in the arm, as well as how much fat and muscle people have, so you can't just rely on a spot always being safe for an injection in everyone without checking you haven't landed in a big blood vessel.
  • · Replies 287 ·
29K
  • · Replies 20 ·
325K
