Thread Closed
Magnitude of electric force
Share Thread
Mar23-08, 07:19 PM   #1
Four point charges are placed at the four corners of a square. Each side of the square has a length L.
Find the magnitude of the electric force on q2 due to all three charges q1 , q2 , q3
and q4. Given L=1 and q= 1.38 μC. Answer in N
http://rs209gc2.rapidshare.com/files...f5e75220df.jpg
Photo of problem ^
2. Relevant equations
3. The attempt at a solution
http://rs220l32.rapidshare.com/files...3_19-17-38.jpg
Photo of work ^
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar24-08, 05:48 PM   #2
Recognitions:
Homework Helper Homework Help
Since you give units of N and microcoulombs in your statement, you are presumably working in SI units. Right off, I'd say check your value for k: I believe it is off by three orders of magnitude... (In your statement, I think you want the net force on q2 from the other three charges, so you don't want to type 'q2' again...)
Also, watch your forces and components. For starters, what is the distance along the diagonal of the square? What is the force between the diagonally opposed charges?
Mar25-08, 06:07 PM   #3
Well the diagonal is also 1. K should = 8.99E9. I still get the wrong answer.
Mar25-08, 07:13 PM   #4
Recognitions:
Quote by bastige View Post
If the side of a square is 1, how long is the diagonal?
Mar25-08, 08:50 PM   #5
A^2 + B^2 =c^2
1^2+1^2=c^2
2=c^2
1=c
Mar25-08, 09:06 PM   #6
Square root of 2 is 1?
Mar25-08, 09:49 PM   #7
Quote by Snazzy View Post
hmm...good point, guess i shouldn't do this in my head. well, its 1.41421. Where Do i need to use it? I didn't have r in my final formula? where did i go wrong?
Mar25-08, 09:54 PM   #8
Recognitions:
The value for c you just calculate is what you will use in Coulomb's Law for the force between the diagonally opposite charges. Since the formula calls for r^2, you could use r^2 = 2 there.
Mar25-08, 10:11 PM   #9
Quote by dynamicsolo View Post
??????I'm sorry, I'm physics illiterate
Mar26-08, 01:55 PM   #10
Recognitions:
You have the equation for the force
kqq/(r^2) , which is Coulomb's Law.
In the image you show for your work, the force for the "southeast" diagonal should be using 2 in the denominator, instead of 1, since the distance squared between the two charges q2 and q4 is 2 .
Thread Closed
Similar discussions for: Magnitude of electric force
Thread Forum Replies
MAgnitude of electric Field Advanced Physics Homework 1
magnitude and direction of electric force (file attached) Introductory Physics Homework 6
magnitude of an electric force problem with vectors Introductory Physics Homework 3
Magnitude of Electric Field Introductory Physics Homework 9
how to calculate the magnitude of force when some force is applied at far away distan Mechanical Engineering 1
