Wigner-Eckart Thm: Calc Double Bar for Electric Dipole Op
  • Context: Graduate
  • Thread starter Thread starter jdstokes
    Theorem
The discussion revolves around the application of the Wigner-Eckart theorem to calculate the reduced matrix element (double bar) for the electric dipole operator, which is proportional to the position operator. Participants explore whether the position operator qualifies as an irreducible spherical tensor operator and discuss methods for computing the double bar in this context.
  • Some participants assert that the position operator is an irreducible spherical tensor operator of spin 1, while others seek clarification on how this conclusion is reached.
  • There is a discussion on the appropriate choice of components for the position operator, with references to using combinations like x + iy, x - iy, and z.
  • One participant emphasizes that the Wigner-Eckart theorem allows relating multiple matrix elements to one or two reduced matrix elements, but does not provide a method for computing the reduced matrix element itself.
  • Concerns are raised about evaluating the matrix element \(\langle j'm' | z | jm \rangle\), particularly regarding the nature of the variable z and its relationship to spherical harmonics.
  • A later reply clarifies that the evaluation involves a complete basis with a "non-angular" index, which is essential for understanding the transformation properties of spherical tensor operators.
Participants express differing views on the classification of the position operator as an irreducible spherical tensor operator, and there is no consensus on the evaluation of the matrix element involving z. The discussion remains unresolved regarding the specifics of these evaluations and the implications for the Wigner-Eckart theorem.
Participants note the importance of careful consideration of the m values when applying the Wigner-Eckart theorem, as well as the need for explicit integrals to compute the reduced matrix element.
jdstokes
Given a rank-k spherically symmetric tensor operator [itex]\hat{T}^{(k)}_q[/itex] (in other words a family of 2k + 1 operators satisfying [itex][J_z,T_q^{(k)}] = q T_{q}^{(k)}[/itex] and [itex]J_{\pm},T_q^{(k)}] = \sqrt{(k\pm q + 11)(k \mp q)}T_{q\pm 1}^{(k)}[/itex] for all k.
We have the Wigner-Eckart thorem
[itex]\langle j',m' |T^{(k)}_q|j,m \rangle = \frac{1}{\sqrt{2j+1}}\langle jk; mq | jk; j'm' \rangle\langle j' || T^{(k)} || j \rangle[/itex]
where the ``double bar'' is independent of m, m' and q.
I want to calculate the double bar for the electric dipole operator (proportional to the position operator). I'm expecting the answer to be proportional to [itex]\sqrt{2j+1}[/itex].
The first thing to answer is whether the theorem applies, ie is the position operator an irreducible spherical tensor operator. Secondly, how would I go about computing the double bar in this case?
I'm a bit rusty on this, so if I tell nonsense, I hope to be corrected.
But I would say, yes, the position operator is an irreducible spherical tensor operator of spin 1. Only, the 3 components, x, y and z, are not the "m" components. I guess you have to use something like x + iy, x - iy and z.
As vanesch says: you can use W-E Theorem here as long as your careful about what m value to use ([itex]r^{\pm 1}\propto x\pm iy[/itex], [itex]r^0\propto z[/itex]).
The WE Theorem does not tell you how to compute the reduced matrix element ("double-bar") - to compute that, you must go ahead and actually do the integral explicitly. The power of WE is that it allows you to RELATE several matrix elements to only one or two reduced matrix elements. So all you have to do is find the Clebch-Gordan coefficients (table) and compute one or two integrals (as opposed to tens of integrals!). In fact, sometimes you don't even have to compute them: if, for example, you are taking the ratio of matrix elements, sometimes the reduced matrix element cancels and you don't have to do a single integral (yay!).
Thanks for responding guys.
Can you tell me how you knew that r was an irred spherical tensor and moreover how did you deduce that the components were [itex]x\pm iy,z[/itex].
How does one evaluate [itex]\langle j'm' | z | jm \rangle[/itex]. This seems a little bit strange because z is a variable which extends to plus or minus infinity whereas the spherical harmonics only have [itex]\theta,\phi[/itex] dependence.
That's because you forgot the "non-angular" index. Look at http://en.wikipedia.org/wiki/Wigner-Eckart_theorem
for instance. The idea is that you have a complete basis, which as a "non-angular" index n (which can consist of several indices if you want), but which are eigenfunctions of L^2 and Lz (the j and m rotation group indices).
A rotation applied to the state |n,j,m> will then only mix the m-values.
What is a spherical tensor operator ? (or better, a set of spherically symmetric operators) It is a set of operators T_k that, under rotation, transform within this set, in a linear combinations of themselves, just like a set |j,m> does.
  • · Replies 0 ·
