Frequency of a particle? Frequency of what?
  • Context: Graduate
  • Thread starter Thread starter WraithM
    Frequency Particle
The discussion revolves around the concept of frequency in relation to particle-wave duality in quantum physics. Participants explore the meaning of frequency for particles, particularly in the context of wave-functions and probability distributions, while addressing the ambiguity in educational materials regarding this topic.
  • One participant expresses confusion about what frequency measures for particles, questioning the concept of "cycles of what" in relation to particle-wave duality.
  • Another participant explains that the peaks in the probability distribution indicate where a particle is likely to be found, linking this to the concept of momentum and frequency through Fourier analysis.
  • A participant references the de Broglie relationship to describe how a particle can be associated with a wave-function and its frequency.
  • There is a correction regarding the interpretation of wavefunctions for particles with specific momentum, emphasizing that such wavefunctions do not exhibit spatial variation in probability density.
  • A follow-up comment questions whether the variation discussed pertains only to the phase of the wavefunction, indicating a need for clarification on this aspect.
Participants do not reach a consensus on the interpretation of frequency in relation to particles, with multiple viewpoints and corrections presented throughout the discussion.
The discussion highlights the complexity of understanding frequency in quantum mechanics, particularly regarding the definitions and implications of wave-functions and probability distributions. There are unresolved aspects related to the interpretation of spatial variation and the nature of frequency itself.
WraithM
Okay, I have a quantum physics problem set, and I would really like to have a clear understanding of what I'm doing before I get into the thick of it.
This is probably incredibly cliche, but I'm having trouble understanding particle-wave duality. I have no problem with the concept of a particle exhibiting wave-like features; however my teacher and textbook are very ambiguous about the frequency and wavelength of particles.
I have no problem with the fact that a photon, an electron, or whatever have frequency, considering that different colors exist :D and other such examples. I'm just not exactly clear on what exactly the frequency is measuring.
So, frequency is defined as the number of cycles per second. My question is in relation to particles "cycles of what?"
So, a wave (as in, ones found at the beach) frequency is measured by number of waves that go by per second. Sound is measuring change in pressure. (I appologize for poor use of words, but please try to understand what I'm getting at.) Then when I get to particles, frequency of a particle is... uh... what?
As I said, I have no problem with the fact that frequency of a particle exists. I have a problem with exactly what the frequency is measuring. Frequency of a particle is the number of cycles of _______ per second. I'm wondering what goes into that blank spot.
Thank you for considering my question and such, I know it probably seems silly, but I honestly can't find a straight answer for this question.
-Matt Wraith
The peaks are in the probability distribution of where you are likely to find the particle if you measure its position. Only if you know the momentum perfectly, and thus have maximum uncertainty about the position, will the distribution look like a plane wave where the peaks are equal in size in all directions off to infinity (each possible momentum corresponds to a unique frequency for any given particle); if you've localized the position enough so the probability distribution has a "hump" in it, then by fourier analysis this can be treated as the sum of a lot of plane waves with different possible frequencies, and thus a lot of possible momenta.
Careful Jesse; the wavefunction for a given momentum is something like exp[ip.x] --- which has constant modulus over all space and time. Specifically, there is exactly no spatial variation in the probability density. What you've written sounds almost like there is a plane-wave distribution for the probability density, which isn't true.
Ah, so it's only a spatial variation in the phase? I haven't studied this stuff in a while...
  • · Replies 26 ·
  • · Replies 78 ·
