Depth of a cone rate problem (question about the equation I'm using)
  • Thread starter Thread starter KatieLynn
    Cone Depth Rate
The discussion focuses on solving a related rates problem involving a conical tank with a diameter of 10 feet and a height of 12 feet. The volume of the cone is expressed as V = (1/3)πr²H, where r is the radius and H is the height of the water. The user is tasked with finding the rate of change of the water depth (dH/dt) when the water is 8 feet deep, given that water flows into the tank at a rate of 10 cubic feet per minute (dV/dt = 10). The user correctly identifies the need to relate the radius to the height using similar triangles to solve for dH/dt.
  • Understanding of related rates in calculus
  • Knowledge of the volume formula for a cone: V = (1/3)πr²H
  • Ability to apply the concept of similar triangles
  • Familiarity with differentiation techniques
  • Study the application of related rates in calculus problems
  • Learn how to derive relationships using similar triangles
  • Practice solving volume-related problems involving cones
  • Explore the concept of implicit differentiation in calculus
Students studying calculus, particularly those focusing on related rates problems, as well as educators seeking examples of practical applications of geometric volume concepts.
KatieLynn
A conical tank (with vertex down) is 10 feet across the top and 12 feet deep. If water is flowing into the tank at a rate of 10 cubic feet per minute, find the rate of change of the depth of the water when the water is 8 feet deep.
Cone: V= (Ah/3)
Right Circular Cone: V=[(pi)(r^2)(h)]/(3)
So on this on I'm confused about the equation I need to derive to begin with..
I looked up the volume of a cone and it had two choices (stated above)
So I think I need to use just the cone one because the problem doesn't say its a right circular cone. Is that correct?
Assuming I do in fact need to use V= (Ah/3)
Do I then plug in A=(pi)(r^2) which is the area of a circle? the book says A equalls the area of the base, which appears to be a circle to me...
ok the volume of the cone is
[tex]V=\frac{1}{3}r^{2}\pi H[/tex]
The info that you know are:
[tex]\frac{dV}{dt}=10[/tex], [tex]r=5[/tex]
We need to find [tex]\frac{dH}{dt}=?[/tex] when H=8(be carefule here, you are not to plug this value for H in, immediately on the equation for the volume, since H (depth) is changing). Now try to find a relation between the radius of the circle on the cone when H=8, using these information.
Draw a picture it usually helps.
