Can Argon Gas Remove Oxygen from Liquid?
  • Context: High School
  • Thread starter Thread starter nuclear75
    Liquid Oxygen
Argon gas can effectively remove oxygen from a liquid by reducing the partial pressure of oxygen through dilution. The process relies on the principle that the amount of dissolved gas in a liquid is influenced by temperature and pressure. While this method is viable, its cost-effectiveness and efficiency compared to other techniques remain uncertain.
  • Understanding of gas laws and partial pressure
  • Knowledge of gas solubility principles
  • Familiarity with liquid-gas interaction dynamics
  • Basic concepts of temperature effects on gas solubility
  • Research the cost-effectiveness of argon gas compared to other inert gases for oxygen removal
  • Explore methods for measuring dissolved gas concentrations in liquids
  • Investigate the impact of temperature on gas solubility in various liquids
  • Learn about alternative oxygen removal techniques, such as vacuum degassing
Chemical engineers, industrial chemists, and professionals involved in liquid processing or gas management will benefit from this discussion.
nuclear75
Can oxygen be removed from a liquid using argon gas?
I suppose so. The amount of dissolved gas in a liquid is just a function of temperature so if you add enough argon and remove any gas the partial pressure of oxygen will gradually reduce as it is dilluted out. Not sure if this is the cheapest/most effective method.
  • · Replies 25 ·
  • · Replies 19 ·
16K
  • · Replies 32 ·
  • · Replies 16 ·
