"Assortment of Structural Steel Beams"&amp
  • Thread starter Thread starter sahar_soltani
    Steel Structural
The discussion centers on the assortment problem faced by Itsa Steel Company, which manufactures structural steel beams indexed by strength levels j = 1 to N, where j = 1 represents the heaviest beam. The company must satisfy demand D(j) for each strength while managing setup costs s(j) and potential losses incurred when supplying beams of lesser strength k (where k <= j). The optimal assortment model must balance manufacturing costs against demand fulfillment and weight-related losses.
  • Understanding of structural steel beam strength and weight relationships.
  • Familiarity with demand forecasting and cost management in manufacturing.
  • Knowledge of optimization models in supply chain management.
  • Basic principles of loss calculation related to product specifications.
  • Research optimization techniques for inventory management in manufacturing.
  • Learn about cost-benefit analysis in production decision-making.
  • Explore demand forecasting methods specific to industrial manufacturing.
  • Investigate case studies on assortment planning in steel production.
Manufacturing engineers, supply chain analysts, and operations managers involved in steel production and inventory optimization will benefit from this discussion.
sahar_soltani
[SOLVED] &amp;amp;quot;Assortment of Structural Steel Beams&amp;amp;quot;&amp;amp;amp
Hi,
Dose anybody know the solution for this problem? Please, help.
Thanks,
A Japanese industrial firm, Itsa Steel Company, manufactures structural beams of a standard length. The strength of a beam depends on its weight, and Itsa Steel indexes the various strengths it can make as j = 1, 2, ...,N, where j = 1 is the heaviest beam and j = N is the lightest. Assume that if a customer requests Strength k, then Itsa Steel may, if it chooses, supply the demand by a beam of possibly greater Strength j, where j < k. Itsa Steel must solve the following assortment problem: The demand requirement for Strength j is D(j) beams; all demand must be satisfied. If Itsa Steel decides to manufacture Strength j, then it incurs and expensive setup cost, s(j). If the company meets the demand requirement D(j) by shipping beams of Strength k, where k <= j, then the company incurs a loss of h*[w(k)-w(j)]*D(j), where w(k) and w(j) are therespective weights of the beams and h is the cost per unit of weight.Formulate a model that will enable Itsa Steel to decide an optimalassortment of strengths to manufacture and the corresponding amounts of each.
sahar_soltani said:
Hi,
Thanks,
A Japanese industrial firm, Itsa Steel Company, manufactures structural beams of a standard length. The strength of a beam depends on its weight, and Itsa Steel indexes the various strengths it can make as j = 1, 2, ...,N, where j = 1 is the heaviest beam and j = N is the lightest. Assume that if a customer requests Strength k, then Itsa Steel may, if it chooses, supply the demand by a beam of possibly greater Strength j, where j < k. Itsa Steel must solve the following assortment problem: The demand requirement for Strength j is D(j) beams; all demand must be satisfied. If Itsa Steel decides to manufacture Strength j, then it incurs and expensive setup cost, s(j). If the company meets the demand requirement D(j) by shipping beams of Strength k, where k <= j, then the company incurs a loss of h*[w(k)-w(j)]*D(j), where w(k) and w(j) are the respective weights of the beams and h is the cost per unit of weight.Formulate a model that will enable Itsa Steel to decide an optimal assortment of strengths to manufacture and the corresponding amounts of each.
For starters the wording of this problem is somewhat confusing.
"Assume that if a customer requests Strength k, then Itsa Steel may, if it chooses, supply the demand by a beam of possibly greater Strength j, where j < k."
Does this mean that the weight of the j beam is less than the k beam or that the greater Strength j beam preceeds alphabetically the lesser strength k beam?
"If the company meets the demand requirement D(j) by shipping beams of Strength k, where k <= j,".
Again are k, j weight grades or strength grades?
Chris
Chris,
Thanks,
I don't have any more information about it, but I think j and k are strength grades; also there is a relationship between strength, and weight. This is what I think. I hope it may help.
10K
  • · Replies 87 ·
9K
11K
