Purple stone, what are the likely contents?
  • Thread starter Thread starter Ulysees
The discussion centers around the identification of a purple stone found by a participant, exploring its potential as a useful ore or mineral. Participants consider various possibilities regarding its composition and characteristics, including types of minerals and testing methods.
  • One participant inquires about the type of ore a purple stone might be, suggesting it could be useful.
  • Another participant requests a picture to better assess the stone's characteristics.
  • A participant mentions that the color of the stone may not be accurately captured in photographs and asks about online databases for mineral recognition.
  • One suggestion is to test various properties of minerals to identify the stone, emphasizing the need for a pure sample rather than a mixture.
  • Bornite, a copper-iron sulfide, is proposed as a possible identification, noted for its color change upon tarnishing.
  • Another participant points out that many purple gems exist, including amethyst and certain types of fluorite, and suggests that a picture would help clarify the identification.
  • The participant who found the stone describes it as rough rather than crystal-like, speculating it might resemble a rare type of marble.
  • Lapis lazuli and some turquoise variants are mentioned as other possibilities for purple stones.
  • Marble is described as primarily composed of calcium carbonate, with a suggestion to test for fizzing in acid as a means of identification.
Participants express various hypotheses about the stone's identity, with no consensus reached on its exact nature. Multiple competing views regarding potential identifications remain present throughout the discussion.
Participants note the importance of visual characteristics and physical tests for accurate identification, but there are limitations due to the lack of a clear image and the potential for the stone to be a mixture of minerals.
Ulysees
I found a purple stone and was wondering if it was a useful ore. All rock where it was found was the same type.
Can anyone guess what type of ore a purple stone might be?
No. can you post a picture?
I've taken one with my cellphone, but the colour is not reproduced at all, and also it's blurred.
Is there any online database for the recognition of ores?
You can test various properties of minerals to get a pretty good idea of what you've got. See here: http://www.rockhounds.com/rockshop/mineral_id/
For that to be of any use you'll have to be sure that you've got a sample of just one mineral rather than a rock that could be a mixture of many minerals.
Bornite, a copper-iron sulfide, turns blue and or purple when it tarnishes. It has the largest percent of copper out of the major sulfide ore minerals.
Are you sure about the type of your stone?
There are many purple gems too... Usually found as massive rocks like purple quartz (Amethyst) or a specific branch of Flourite & many more...
A picture will solve the mystery.
Here are some pictures of an amethyst;
http://www.mindat.org/min-198.html
You can use the specifications given to test what the stone is. The most important one is its density which can be performed without any instrument. The picture is just too clasy & stylish in this link, but you will get an idea :)
Regards,
Mubashir
Thanks, it's not crystal-like at all. It's more like a rough rock.
I think that may be what marble looks like in its natural state. If I get hold of a proper camera I'll take a picture, it may be some rare sort of marble.
lapis lazuli varies from intense blue to purple. Some turquoise variants are light purple.
Marble is made mostly of calcium carbonate (like limestone and calcite crystals). It will fizz slightly in the presence of a weak acid. I've used dilute HCl in the past but I think vinegar does the trick too. Give it a go and see if you get any bubbles forming.
  • · Replies 19 ·
  • · Replies 20 ·
