Why Electrolysis of ZnSO4 Won't Coat with Zinc Metal
The discussion centers on the electrolysis of aqueous zinc sulfate and why it does not result in the coating of zinc metal. Participants explore the reactions occurring at the electrodes and the factors influencing the preferential discharge of ions during electrolysis.
  • One participant notes that the reaction involving sulfate and protons has a more positive electrode potential than the hydrogen evolution reaction, suggesting that H2SO3 would form at the cathode.
  • Another participant emphasizes that cations assist in the transfer of protons in the solution, indicating that ionic strength affects conductivity.
  • A question is raised about whether the electrode potential alone can determine the outcome of the electrolysis process.
  • Concerns are expressed regarding the stoichiometry of the reactions, with one participant pointing out that the reaction forming sulfuric acid requires more protons than the hydrogen gas formation reaction.
  • Standard electrode potentials for both reactions are provided, highlighting the difference in their values.
  • Clarification is made that the discussion pertains to an electrolytic pathway rather than a galvanic one, which may influence the interpretation of the electrode potentials.
Participants express differing views on the role of electrode potentials and the behavior of ions in solution. There is no consensus on the exact reasons for the preferential discharge of H+ over Zn2+ during electrolysis.
Participants mention the importance of the aqueous solution and the nature of the electrolytic cell, but the discussion does not resolve the implications of these factors on the electrolysis process.
Hevonen
[SOLVED] Electrolysis, coating
2. Relevant equation
Why electrolysis of aqueous zinc sulfate is not used for coating with zinc metal?
The following reaction has more positive electrode potential: (SO4)2- + 4H+ + 2e => H2SO3 + H2O than the reaction 2H+ + 2e- => H2(g); so H2SO3 would form at cathode. However, the right answer is that H+(aq) discharged preferentially because cations in solution =H+(aq),Zn2+(aq).
Do you know why?Thank you in advance!
Cations assist in transfer of the proton throughout the solution. It's similar to the notion that water conducts electricity better when it is more "ionic".
Do you mean that I cannot look straight away at the substance of greatest electrode potential?
This question seems to be rather simple - when you have cations in solution it attracts the negatively charged sulfate
In addition this latter reaction requires 4 molar equivalence of protons compared to only 2 for the other reaction.
What are the respective values of the electrode potentials for both reactions and also please inform us on the exact answer for this problem. It seems to me that the conversion of the proton to hydrogen gas would be more favored as the formation of sulfuric acid from sulfate is not favored in many circumstances.
Standard Electrode Potentials:
(SO4)2- + 4H+ + 2e => H2SO3 + H2O, E = +0.17V
2H+ + 2e- => H2(g), E = +0.00V
Exact answer:
Cations in the solution are H+(aq) and Zn2+(aq).
=> H+(aq) discharged preferentially (I do not understand this in the light of above potentials.)
What the answer is referring to is comparing the zinc reactions with that of the proton - in particular note the standard reduction potential of reducing zinc 2+ .
Remember , this isn't a galvanic pathway it is an electrolytic pathway.
Thanks! Now, I understand. The key is the aqueous solution and electrolytic cell.
9K
10K
