Pauli Matrices in higher dimensions
The discussion centers on the construction of Pauli matrices in four spatial dimensions, highlighting the requirement for four 2x2 mutually orthogonal matrices that satisfy specific commutation relations. The conversation emphasizes the necessity of imaginary numbers for constructing these matrices in three dimensions and questions whether a more general extension of complex numbers, such as quaternions, is needed for higher dimensions. Additionally, it references Dirac's use of 4x4 gamma matrices in four-dimensional spacetime, noting that these do not directly address the construction of Pauli matrices in four spatial dimensions. The insights suggest that the limitations in extending Pauli matrices to four dimensions may indicate a deeper issue within the mathematical framework of quantum mechanics.
  • Understanding of Pauli matrices and their properties
  • Familiarity with complex numbers and their extensions, such as quaternions
  • Knowledge of Dirac matrices and their application in quantum mechanics
  • Basic concepts of quantum mechanics, including eigenvectors and commutation relations
  • Research the properties and applications of quaternions in quantum mechanics
  • Study Dirac gamma matrices and their role in four-dimensional spacetime
  • Explore the theorem by Wiseman regarding mutually conjugate bases in quantum systems
  • Investigate the implications of tensor multiplication in constructing higher-dimensional matrices
Physicists, mathematicians, and students of quantum mechanics interested in the theoretical foundations of higher-dimensional systems and the limitations of existing mathematical frameworks in quantum theory.
Kazza_765
This has been bugging me for a while, but feel to tell me if it's a nonsensical or silly question..
Suppose there were 4 spatial dimensions instead of 3. How would we go about constructing the Pauli matrices?
Assuming each matrix still only has 2 eigenvectors, we require 4, 2x2 mutually orthogonal matrices satisfying the commutation relations. As well as that, the eigenvectors of any matrix must be expressible as linear combinations of the eigenvectors of any other, ie. each set of eigenvalues forms a basis.
It seems to me that the only reason we are able to do this in 3 dimensions is through the use of imaginary numbers. Without imaginary numbers we can only form the two bases {(1,0), (0,1)} and {(1,1), (1,-1)}. Is there perhaps some more general extension of complex numbers that is necessary to extend the Pauli matrices to dimensions >3?
Look up quaternions.
Or you could take Dirac's approach. He solved the problem in 4 spacetime dimensions by using 4x4 matrices. For that, look up gamma matrices.
The Dirac matrices do not answer the question, they are for Minkowski space, 3 dimensions of space and 1 of time, not the 4 spatial dimensions that are at issue. The question is a deeper one than it appears. For position and momentum only 2 conjugate bases are assumed, connected by a Fourier transform. For discrete systems, 3 and more conjugate bases are possible. A theorem by Wisemen (? of quantum cryptography fame) has shown that the number of mutually conjugate bases scale as the log of the state space. An 8 state system should have 4 mutually conjugate bases. Therefore, there should be an unlimited number of mutually conjugate bases for the infinite dimension case of position and momentum, but I've never seen them discussed.
A case can be made that the mathematics used in quantum mechanics are overkill, they have more degrees of freedom than the physics does. This means they could be a red herring, providing false clues about the fundamentals of quantum mechanics. The fact that Pauli spin matrices can be constructed for 3 spatial dimensions but not 4 suggests they might be a convenient accident. The observation that they cannot be easily extended to 4 spatial dimensions is rather insightful.
To see this, tensor multiply each base by itself. Two of them will yield bases conjugate to each other applicable to a 4-state system, but the third one (the one with imaginary components) yields a matrix that looks like a basis (orthonormal vectors) but is not Hermitian, and therefore does not represent a physically realizable measurement.
  • · Replies 22 ·
