Find The Value of X Given (x,2)
  • Thread starter Thread starter LLS
    Value
The problem involves determining the value of X in a geometric context, specifically related to a circle and a right triangle formed by its radii. The original poster expresses confusion about how to approach the problem.
  • Participants discuss the significance of the right triangle and the radius of the circle, questioning how these elements relate to finding the value of X. There is uncertainty about the calculations involving the radius and the coordinates.
Some participants have offered hints regarding the radius and its relationship to the coordinates. There is an ongoing exploration of the calculations needed to derive the value of X, with multiple interpretations being considered.
Participants are working with a specific geometric setup involving a circle and its properties, but there is a lack of clarity regarding the initial conditions and the exact relationship between the elements involved.
LLS
[SOLVED] Find The Value of X Given (x,2)...
In the figure above, Lines AB and BC are radii of the circle with center B. What is the value of X? (see attached)
I am lost. I don't know how to begin to solve this problem.
<ABC is a right triangle. Does that factor into the equation?
It would appear that the answer has to be a negative number.
Hint: find the radius of the circle.
Would the radius be 5?
The answer is -5?
The answer is -5?
No. You must subtract 5 from the x coordinate of the center of the circle...What does that give?
That would be 1 - 5 = -4
(-4, 2)
(-4, 2)
Yup!
  • · Replies 27 ·
