Solve Kepler's 3rd Law Homework: Satellite Circular Orbit Density
  • Thread starter Thread starter Reverie29
    Law
The problem involves determining the density of a planet based on the orbital period of a satellite in a circular orbit very close to its surface. The context is rooted in Kepler's laws of planetary motion and gravitational principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between the orbital period and the mass and density of the planet, with attempts to rearrange Kepler's third law. Questions arise regarding the correct interpretation of density and the formulas involved.
Several participants are exploring different aspects of the problem, including the correct formula for density and the implications of the calculations. There is a recognition of confusion regarding the relationship between mass, volume, and density, with some guidance provided on the formulas needed.
Participants note the assumption of uniform density for the planet and the need for a correct understanding of the volume of a sphere in relation to density calculations. There is also mention of potential errors in calculations leading to unexpected results.
Reverie29
A satellite is in a circular orbit very close to the surface of a spherical planet. The period of the orbit is 2.49 hours.
What is density of the planet? Assume that the planet has a uniform density.
T^2 = (4(pi)^2*r^3) / GM
Okay, so I converted the period into seconds and got 8964 seconds.
Then I rearranged the equation to get
M/r^3 = 4(pi)^2 / GT^2, assuming that M/r^3 would get me density.
So then according to that Density = 4(pi)^2 / (6.67e-11 N*m^2/kg^2)(8964 s)^2 which gives 7366 kg/m^3 which is not correct.
Or am I missing something about density? Density is mass divided by area. Should I be finding a radius to find the area and then find the mass somehow... I don't know. I'm confused on what to do.
[tex]\rho = \frac{M}{V}[/tex]
Assuming the planet is a perfect sphere, [itex]V=\frac{4}{3} \pi r^3[/itex]
So
[tex]\rho = \frac{M}{\frac{4}{3} \pi r^3} = \frac{3M}{4\pi r^3}[/tex]
Your problem is in assuming that M/r^2 gives you density.
Density is mass divided by volume. So what is the formula for the volume of a sphere?
Okay.
The density of a sphere is = 3M / 4(pi)r^3. And I have already solved for M/r^3. I tried multiplying by 3 and dividing by 4pi, but still got an incorrect answer. I got 17,356 kg/m^3.
Should I be looking at another equation?
3/(4pi)<1. Why did your answer increase?
[tex]T^2=\frac{4\pi r^3}{GM}[/tex]
[tex]\frac{1}{T^2}=\frac{GM}{4\pi r^3}[/tex]
[tex]\frac{1}{T^2}=\frac{G}{3} \frac{3M}{4\pi r^3}[/tex]
[tex]\frac{1}{T^2}=\frac{G}{3} \rho[/tex]
and then you got [itex]\rho[/itex] to be that value? If so and you calculated correctly...that should be the answer.
I have no idea why it increased! I guess I must be calculator retarded. I've got it now, thanks!
