How Long Can an Atom Stay in an Excited State?
  • Context: Graduate
  • Thread starter Thread starter Ahmed Abdullah
    Atom Excited State
The discussion centers on the duration an atom can remain in an excited state and the factors that may influence this duration. Participants explore concepts related to optical transitions, spontaneous and stimulated emission, and the interaction between atoms and electromagnetic fields.
  • One participant inquires about the duration of an atom's excited state and whether it can be prolonged.
  • Another participant explains that the lifetime of an excited state is influenced by stimulated and spontaneous emission, noting that stimulated emission typically results in a shorter lifetime compared to spontaneous emission.
  • It is mentioned that the rate of spontaneous emission can be modified by external conditions, such as placing the atom in a resonant cavity, which enhances the emission rate through the Purcell effect.
  • A participant questions what prevents an electron from returning to the ground state immediately after excitation, suggesting that the system's tendency to minimize energy is not straightforward due to the coupling between the atom and the electromagnetic field.
  • Further elaboration is provided on the transition matrix element and its dependence on the wave functions and the operator for decay transitions, indicating that different multipolarities can affect the decay probabilities.
  • Another participant argues that while both the atom and electromagnetic field tend to minimize energy, the conservation of energy implies that one system must remain excited, leading to a discussion on the distribution of energy among degrees of freedom in thermodynamic systems.
Participants express differing views on the mechanisms and implications of energy minimization in coupled systems, with no consensus reached on the nature of the excited state duration or the factors influencing it.
The discussion involves complex interactions between quantum mechanics and thermodynamics, with assumptions about energy states and the behavior of coupled systems that remain unresolved.
Ahmed Abdullah
How long an atom remains excited?
How can we prolong the excited state of an atom? Whether its possible.
Thx
Taking only optical transitions into account, there are only two ways for the atom to emit a photon and get back into the ground state: stimulated emission and spontaneous emission.
In stimulated emission the transition back into the ground state is triggered by another photon of the same energy as the transition back to the ground state. The incident photon "arrives" at the atom and two photons of identical energy and direction come out. In this case the lifetime is in general rather short and depends on the external conditions as we need to shine light on the atom.
Spontaneous emission is a similar process, in which vacuum fluctuations play the role of the triggering photon. In this case the lifetime is longer. The exact value of the spontaneous emission rate is usually calculated by using Fermi's golden rule and depends mainly on the energy of the transition and the mode spectrum of the em-field. Therefore the rate of spontaneous emission can be altered by changing the spectrum of the em-field, for example by placing the atom inside a resonant cavity, which enhances spontaneous emission, which is called the Purcell-effect.
One should also note, that spontaneous emission is a phenomenon, which can only be described in terms of a quantized em-field. Classical physics and "ordinary" qm predict, that there is no spontaneous emission.
Electron promotes to higher E-level by absorbing certain frequency, but system always tends to attain minimum energy; so the electron should return to ground state as soon as possible. Now what I really want to know is- what deter the electron from coming back?
And Cthugha thanks for your response.
deter ?
Anyway, you have a transition matrix element ([tex]< final|O(E_{\gamma}) | final > ) that gives you the probability amplitude for a certain decay. So you see that it depends on the wave functions and the operator for that decay transition - i.e how much O|initial> overlaps with |final>.<br /> The operator here, O(E), depends on what multipolarity the transition requires - and the multipolarity depends on what total angular momenta J and parity the states has(and some more things). So perhaps <final, J = 2|O(E2)|initial, J = 4> is larger than <final, J = 2|O(E4)|initial, J = 4>, then E2 will dominate over E4 in this made up case.<br /> <br /> The same things you have in nuclear physics.[/tex]
Does it really? You have two coupled systems: the atom and the electromagnetic field. According to the argument you mentioned both should tend to attaind minimum energy, but due to conservation of energy one of these systems has to be in an excited state. In usual thermodynamics systems in equilibrium tend to distribute the energy evenly among all degrees of freedom.
In the microscopic picture the number of possible states in phase space is rather analogous to the degrees of freedom in thermodynamics. This means, the atom has only one state (or in case of degeneracy only few states), which corresponds to the given energy. The em-field however has a huge number of states, which match the given energy. For example the components of the momentum vector do not need to have a fixed value, only the magnitude of the vector is fixed. Therefore there are a huge number of possibilities for the em-field to get from the vacuum state to the one-photon state.
So the coupled system has lots of states with one photon and an atom in its ground state and few states with an excited atom and the em-field in its ground state. All possible states have the same final energy, but it is far more likely for the system to be in a state with one photon. However the system reaches a state of higher entropy when a photon is emitted. The usual notion of systems tending towards minimal energy is just a consequence of this behaviour.
  • · Replies 18 ·
