| Thread Closed |
Seems I can't differentiate properly...or I need some help with it. |
Share Thread |
| May14-08, 01:52 PM | #1 |
Recognitions:
Part of a question here... Show that [tex]\frac{d}{dx} \left[ \frac{x}{(4-x^2)^n} \right ] = \frac{1-2n}{(4-x^2)^n} - \frac{8n}{(4-x^2)^{n+1}}[/tex] 2. Relevant equations [tex]\frac{d}{dx}(\frac{u}{v}) = \frac{v\frac{du}{dx}-u\frac{dv}{dx}}{v^2} [/tex] 3. The attempt at a solution So, using the quotient law I get [tex] \frac{(4-x^2)^n \times 1 -(x) \times n(4-x^2)^{n-1} \times -2x}{(4-x^2)^{2n}}[/tex] [tex]=\frac{1-2nx^2(4-x^2)^{-1}}{(4-x^2)^n}[/tex] [tex] =\frac{1}{(4-x^2)^n} - \frac{2nx^2}{(4-x^2)^{n+1}}[/tex] I seem to have the denominators correct but not the numerators. Did I do it wrong or are there more ways to simplify? |
| May14-08, 02:07 PM | #2 |
I can't get the result either... I get the same as you, only a + instead of a - between the fractions...
EDIT Maple backs me up... According to maple the result is: [tex]\frac{1}{(4-x^2)^n} + \frac{2nx^2}{(4-x^2)^{n+1}}[/tex] And no matter what I do I cannot get it to simplify / expand / factor, whatever, into what you have to show... I don't think they are equal. |
| May14-08, 02:11 PM | #3 |
I checked it with Mathematica, Nick89 is correct. The thread starter is off by a sign but
[tex] \frac{d}{dx} \left[ \frac{x}{(4-x^2)^n} \right ] = \frac{1-2n}{(4-x^2)^n} - \frac{8n}{(4-x^2)^{n+1}} [/tex] definitely doesn't hold. |
| May14-08, 02:18 PM | #4 |
Recognitions:
If you are really feeling unconfident that you might be missing a simplification, try putting say x=0 and n=2 and comparing the results of the two. They are different, so your's in right (once you fix that sign error).
| May14-08, 02:21 PM | #5 |
Recognitions:
Well I guess I should post the entire question:
[tex]I_n =\int _{0} ^{1} \frac{1}{4-x^2}[/tex] for n=1,2,3,... Verify that [tex] \frac{d}{dx} \left[ \frac{x}{(4-x^2)^n} \right ] = \frac{1-2n}{(4-x^2)^n} - \frac{8n}{(4-x^2)^{n+1}}[/tex] and hence prove that [tex]8I_{n+1}=(2n-1)I_n +\frac{1}{3^n}[/tex] EDIT: Ahh...-ve*-ve=+ve...Will fix now... but the question being wrong is really odd. |
| May14-08, 02:56 PM | #6 |
[tex]x^2=-(4-x^2)+4[/tex] and simplify the result. |
| May14-08, 03:19 PM | #7 |
Recognitions:
I hate questions where you always need to remember that 1-1=0
| May14-08, 03:33 PM | #8 |
In this one you know that you want to have 4-x^2 on the top of the 2nd term to split it up into the two types of terms that appear in the answer. So you're like I need to express the numerator [tex]x^2[/tex] in the form [tex]a(4-x^2)+b[/tex] for some numbers a and b to get the expression into the form that I want. |
| Thread Closed |
Similar discussions for: Seems I can't differentiate properly...or I need some help with it.
| Kinetic Friction, did I do this properly? | Introductory Physics Homework | 9 | ||
| How do I properly prepare for physics? | Academic Guidance | 6 | ||
| how do i properly set up a colpitts oscillator? | Electrical Engineering | 1 | ||
| How do I evaluate this properly? Trig | Introductory Physics Homework | 4 | ||
| How to properly decieve yourself | General Discussion | 1 | ||
