Thread Closed
Wave properties of matter
Share Thread Thread Tools
May18-08, 07:01 PM   #1
Consider the statement below made by a student: "Muons have a higher mass than electrons, but because the energy, E, is related to the wavelength by E=hc/[tex]\lambda[/tex], muons that have the same kinetic energy as electrons will also have the same wavelength."
Do you agree or disagree with this statement? Explain your reasoning.
2. Relevant equations
[tex]\lambda=h/p[/tex] (de Broglie wavelength)
3. The attempt at a solution
The statement seems wrong to me. If you substitute in for [tex]\lambda[/tex] in the first equation, you get cp, but kinetic energy is p^2/(2m) and those two can't be the same (solving for c gives c=v/2).
I'd never seen the first equation before, but looking in my textbook it looks like E is the change in energy of an atom when a photon is absorbed or emitted and I don't know how you could apply it to an electron/muon (can you?)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May18-08, 08:15 PM   #2
Recognitions:
Homework Helper Homework Help
[itex]\lambda[/itex] is different for different objects, so why should E be the same?
E is the total relativistic energy, not p^2/2m. Also, E = hf, where f is the frequency associated with the de Broglie wave.
Just do the simple math. Also, reading up on de Broglie wavelength would be a good idea.
EDIT:
Are you talking about the muons and the electrons having the same energy, by any chance? This is not mentioned in the problem, so I assumed not.
Also, [itex]E=hc/\lambda[/itex] is valid only for massless particles which travel at speed c.
May18-08, 08:35 PM   #3
The question is assuming you have two particles with the same kinetic energy.
>For high speed particles, E is the total relativistic energy, not p^2/2m.
Ok, but I still doubt that cp=Ek for an electron. Is that wrong?
And if f=v/[tex]\lambda[/tex], then E = vp. But v can't be c for an electron, so the equation can't work here (?)
May18-08, 08:38 PM   #4
Sorry, you posted while I was replying. Yes, that's the problem:
"muons that have the same kinetic energy as electrons..."
>Also, is valid only for massless particles which travel at speed c.
I'm guessing this is essentially the answer to the question
Thread Closed
Thread Tools
Similar Threads for: Wave properties of matter
Thread Forum Replies
Matter wave, light wave and water wave Beyond the Standard Model 5
Properties of matter Atomic, Solid State, Comp. Physics 1
Properties of matter Chemistry 2
Properties of matter Advanced Physics Homework 3
Properties of matter Advanced Physics Homework 2
