Relativistic Doppler Shift and a Star breaking up
The discussion revolves around a problem in relativistic physics, specifically focusing on the Doppler shift of light emitted from a star that breaks apart into two remnants. The original poster presents the frequencies of light emitted by the star and its remnants, seeking to determine their velocities and the angle of motion relative to the observer on Earth.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to apply the relativistic Doppler shift equations to find the velocities and angles of the remnants. Some participants question the appropriateness of the equations used, particularly regarding the angle and the relationship between the two remnants. Others suggest considering the conservation of momentum and the implications of the angles involved.
The discussion is ongoing, with participants exploring various approaches to relate the speeds and angles of the remnants. Guidance has been offered regarding the setup of equations based on the observed frequencies, and there is an acknowledgment of potential issues with the provided data. Multiple interpretations of the problem are being examined.
Participants note that the problem may contain inconsistencies in the data, which could affect the ability to find a solution. There is also a focus on ensuring that angles and velocities are correctly represented in the context of the Doppler effect.
TFM
A distant star at rest with respect to an observer on Earth emits light of frequency 6.690 x 10^14 Hz. The star breaks up into two remnants of equal mass, which are observed to emit light of frequency 7.135 x 10^14 Hz and 4.282 x 10^14 Hz
Find the velocities of the remnant and the angle between line of sight and their direction of motion.
[tex]v^{prime} = v \gamma [1 - \beta cos \theta][/tex]
[tex]v^{prime} = v \sqrt{\frac{1 + \beta}{1 - \beta}}[/tex]
I have solved the first part, finding the speed, using:
assuming that since the star was initally at rest, the centre of momentum will remain in the same polace, hence the two parts will fly away from each other.
I got [tex]\beta[/tex] to be 0.47, and the speed of the star remnants to be 0.235c
I am having a small problem with the second part, finding the angle. I am sure I need to use:
with the v primke being the orginal stars frequency. but I am nto sure which of the othe frequencies to use as v, and I am not sure how to get a value of beta to use in this part, since I am sure it will be different to the value in part A.
Any ideas will be greatly appreciated,
TFM
That's the formula for the longitudinal Doppler shift when the source is approaching. It assumes an angle of 180 degrees, so it's not relevant here.
You can't solve the two parts separately. Hint: How are the speed and angle of the two remnants related?
Would you need to use the equation [tex]c = \lambda * frequency[/tex]
so:
[tex]frequency = c/ \lamda[/tex]
so:
[tex]\frac{c}{\lambda}^{prime} = \frac{c}{\lambda} \gamma [1 - \beta cos \theta][/tex]
Or I am going in the worng direction?
TFM
The equation to use is the first one you listed (I'll use f for frequency):
[tex]f' = f \gamma [1 - \beta cos \theta][/tex]
So:
[tex]f' = f \frac{[1 - \beta cos \theta]}{1 - \beta^2}[/tex]
but we don't know beta or theta?
TFM
Of course you don't--that's what you're trying to find! Set up two equations (using the two observed frequencies) and you can solve for the two unknowns.
Don't neglect to answer my question: How are the speed and angle of the two remnants related?
Would the relationship between speed and angle be:
[tex]v_{obseerved} = v*sin \theta[/tex]
TFM
I meant this as two questions:
(1) How are the speeds of each remnant related?
(2) How are their angles related?
These should be easy to answer. Drawing a diagram will help.
Considereing coinservation of momentum, then the momentum before in the Earth Observer frame should be zero, since the star has zero speed. this means that the two stars remnants must have equal and opposite speeds, to keep the center of momentum frame the same. the angle between them must be 180 degrees (Pi)?
TFM
Good! So how will the angles that you use in the Doppler formula relate to each other? How will their cosines relate to each other?
Would one of the remnants have an angle 0f 0, thus the cos would be 1, whilst the other would have 180, with a cos of -1?
TFM
No reason to think so. (But if one did have an angle of 0, then the other must certainly have an angle of 180.) Again, this is a more general case than the simple longitudinal Doppler shift.
Call the angle that one remnant makes [itex]\theta[/itex]. (Draw that diagram!)
Is the daigram required?
TFM
That's a good start. Now mark the angle that each remnant makes with the line of sight. (Assume for all practical purposes that both remnants are located just where the original star was.)
Would that be like this?
TFM
Yes - so now find the velocity components of both stars with respect (parallel) to the line of sight, and relate them back to the velocities of the stars. Note that the star moving away is at the same angle [itex]\theta[/itex] as the star moving toward the observer.
This would be breaking down into components, so, for star Remnant A:
Horizontal speed would be:
[tex]v*cos(\pi - \theta)[/tex]
Vertical speed would be:
[tex]v*sin(\pi - \theta)[/tex]
and for Remnant B:
Horizontal Speed would be:
[tex]v*cos(\theta)[/tex]
[tex]v*sin(\theta)[/tex]
TFM
Almost. The angle should be measured from the position vector that extends from Earth to the star.
In the general formula for Doppler shift you should recognize that [itex]\theta = 0[/itex] corresponds to the ordinary longitudinal formula when the source is receding.
There's no need to find parallel or perpendicular components of the velocity. The [itex]\beta[/itex] in the Doppler formula represents the full velocity, not a component. (Any needed component is taken care of by the [itex]\cos\theta[/itex] factor.)
Fix your diagram (marking the correct angle), then set up two equations, one for each remnant.
Should it be like this then, since I believe you measure angles clockwise
TFM
opps, wrong diagram:
Sorry,
TFM
The issue is not clockwise versus counterclockwise, but that you should be measuring the angle from the forward direction (a vector pointing towards the star). An angle of zero means the source is moving directly away from earth.
That makes sense, so:
TFM
Good. Now set up your two equations.
So, Equation for remnant A:
[tex](6.690*10^{14}) = (4.282*10^{14}) \gamma [1 - \beta cos \theta][/tex]
For Remnant B:
[tex](6.690*10^{14}) = (7.135*10^{14}) \gamma [1 - \beta cos (\pi - \theta)][/tex]
Are these the right equations?
TFM
For some reason you have f and f' reversed. Other than that, those are the right equations. Simplify this expression: [itex]cos (\pi - \theta)[/itex].
Would that simplify down to [tex]sin(\theta)[/tex]
TFM
No. Review your trig identities. Even better, recognize vertical angles in your diagram.
Would it be [tex]sin{\pi + \theta}[/tex]
TFM
No. It's much simpler than that. Look up trig identities related to supplements.
Would it be:
[tex]-cos(\theta)[/tex]
TFM
  • · Replies 16 ·
