Integral of (z^2)dz around a semi-circle in the y >= 0 region.
  • Context: Undergrad
  • Thread starter Thread starter Smin0
    Integral
The discussion revolves around the evaluation of the line integral of the function (z^2)dz around a semi-circle in the upper half-plane, specifically from x=1 to x=-1. Participants explore various parameterizations and methods for calculating this integral, including both complex and real variable approaches.
  • One participant expresses confusion over obtaining a result of 0 for the integral, despite believing it should have a non-zero value due to cancellation with another integral.
  • Another participant suggests using a parameterization of the semi-circle in polar coordinates, specifically z = e^{iθ}, and questions the limits of integration used.
  • Several participants discuss the algebra involved in the integration process, with one noting a potential mistake in the calculation of dz.
  • Another participant provides a detailed calculation using the parameterization and arrives at a different result, prompting questions about the discrepancies in results.
  • Some participants point out algebraic mistakes in earlier calculations and suggest corrections, but no consensus on the final result is reached.
Participants generally agree on the need to parameterize the integral correctly and acknowledge the potential for algebraic errors. However, multiple competing views on the correct evaluation of the integral remain unresolved, with no consensus on the final answer.
Participants note that the integral is evaluated over a contour that includes both the semi-circular path and a straight line segment, and discussions reveal that the presence of poles or singularities in the function could affect the evaluation.
This discussion may be useful for students preparing for exams in physics or mathematics, particularly those studying complex analysis and line integrals.
Smin0
Help! I'm preparing for Prelims (exams taken at the end of the first year of my course in Physics) and I can't do the line integral of (z^2)dz around the open semi-circle counter-clockwise from x=1 to x=-1. However I try to tackle it the answer comes out as 0, when I know it has some size because it cancels out with the straight line integral from -1 to 1 (possibly equal to 2/3, although I've lost the original working). The z is for a complex variable, but if anyone could at least just show me how to parameterize the regular line integral (not for complex, but just in 2D) around the semi-circle that would be so helpful. I've tried everyway I can (barring using cartesian, because I know there's a nice polar way to do it, I just keep coming out 0 when I try though), and it just won't work!
To re-iterate, the integral is (z^2)dz where z = x + iy.
Thank you!
Simon.
Yes, that's a perfectly valid way of doing it. Normally complex variables are written z= x+ iy where x and y are the real and imaginary parts. On the straight line from -1 to 1, z is always real so z= x looks like a perfectly good parameterization.
Thank you!
Simon.
Unfortunately, you haven't show the work that "keeps coming out 0". On the unit circle, [itex]z= cos(\theta)+ i sin(\theta)[/itex] or equivalently but more simply, [itex]z= e^{i\theta}[/itex]. Now, how are you integrating that from 1 to -1? In particular, what limits of integration are you using?
Int((z^2)dz). Also: my GOODNESS that latex took a long time to type out.
Okay, well I thought I'd found the trouble when I realized that [tex]dz = izd\theta[/tex] instead of [tex]ird\theta[/tex], but alas it now comes out to -4. My working this time is as follows (r = 1):
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(cos\theta + isin\theta)^{2}(izd\theta)[/tex]
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(cos\theta + isin\theta)^{2}(icos\theta - sin\theta)d\theta[/tex]
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(icos^{3}\theta - isin^{2}\theta\cos\theta - 2sin\theta\cos^{2}\theta - cos^{2}\theta\sin\theta + sin^{3}\theta - i2sin^{2}\theta\cos\theta)d\theta[/tex]
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(i(1 - sin^{2}\theta)cos\theta - isin^{2}\theta\cos\theta - 2sin\theta\cos^{2}\theta - cos^{2}\theta\sin\theta + (1 - cos^{2}\theta)sin\theta - i2sin^{2}\theta\cos\theta)d\theta[/tex]
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(icos\theta - 3isin^{2}\theta\cos\theta - 3sin\theta\cos^{2}\theta + sin\theta)d\theta[/tex]
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(sin\theta - 3sin\theta\cos^{2}\theta)d\theta + i\int^{\pi}_{0}(cos\theta - 3cos\theta\sin^{2}\theta)d\theta[/tex]
[tex]\int{z}^{2}{dz} = \left[- cos\theta - cos^{3}\theta\right]^{\pi}_{0} + i\left[sin\theta - 3sin^{3}\theta\right]^{\pi}_{0}[/tex]
[tex]\int{z}^{2}{dz} = ( - 1 - 1 - 1 - 1) + i(0 - 0 - 0 - 0)[/tex]
[tex]\int{z}^{2}{dz} = -4[/tex]
What am I doing wrong here?
o___o
... okay, and when I do it:
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(e^{i\theta})^{2}(ie^{i\theta}d\theta)[/tex]
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(e^{i2\theta})(ie^{i\theta}d\theta)[/tex]
[tex]\int{z}^{2}{dz} = i\int^{\pi}_{0}(e^{i3\theta})d\theta[/tex]
[tex]\int{z}^{2}{dz} = i\left[\frac{1}{i3}e^{i3\theta}\right]^{\pi}_{0}[/tex]
[tex]\int{z}^{2}{dz} = \left[\frac{1}{3}e^{i3\theta}\right]^{\pi}_{0}[/tex]
[tex]\int{z}^{2}{dz} = \left(- \frac{1}{3} - \frac{1}{3}\right)[/tex]
[tex]\int{z}^{2}{dz} = - \frac{2}{3}[/tex]
which is what I believe to be the right answer ... how come it works this way but not the other?
Minus signs ...
That should be [tex]-- 1 -- 1 -- 1 -- 1 = + 1 + 1 + 1 + 1 = 4[/tex] sorry. Still wrong though :(.
Oh, and:
should be
[tex]\int{z}^{2}{dz} = \left[- cos\theta - cos^{3}\theta\right]^{\pi}_{0} + i\left[sin\theta - sin^{3}\theta\right]^{\pi}_{0}[/tex]
Just to be sure, this is contour you want to integrate z^2 on?
[tex] \setlength{\unitlength}{2cm}<br /> \begin{picture}(4,3)<br /> \linethickness{0.4mm}<br /> \qbezier(1,1)(1,2)(2,2)<br /> \qbezier(2,2)(3,2)(3,1)<br /> \linethickness{0.2mm}<br /> \put(2.1,2.20){Imag}<br /> \put(3.30,0.95){Real}<br /> \put(2,0.75){\vector(0,1){1.5}}<br /> \put(.75,1){\vector(1,0){2.5}}<br /> \put(.835,.75){-1}<br /> \put(2.95,.75){1}<br /> \end{picture}[/tex]
Lets call that contour "[tex]\gamma[/tex]", and also the same closed contour "[tex]\Gamma[/tex]".
Since z^2 has no poles we know that;
[tex]\oint_\Gamma z^2 \mathrm{d}z = 0[/tex]
And since we can break up [tex]\Gamma[/tex] into two parts ([tex]\gamma[/tex] and the line segment from -1 to 1), we get;
[tex]\oint_\Gamma z^2 \mathrm{d}z = \int_\gamma z^2 \mathrm{d}z + \int_{-1}^1 z^2 \mathrm{d}z = 0[/tex]
so
[tex]\int_\gamma z^2 \mathrm{d}z = -\int_{-1}^1 z^2 \mathrm{d}z[/tex]
And finally yes, [tex]\gamma[/tex] is parameterized (in [tex]\mathbb{C}[/tex]) by [tex]e^{it}[/tex] with t from 0 to pi. If you want to do it in [tex]\mathbb{R}^2[/tex] just take imaginary and real part.
It looks like you just made some sort of simple algebra mistake in your first attempt with cos(q)+isin(q)
Yep, that's the line integral. And I got the other part, from -1 to 1 along the x-axis, I just needed to learn to do the other part explicitly to prove that the closed contour sums to 0. I still can't see what's wrong with the integration in cosines and sines, but it comes out as the wrong answer - if anyone can see where I've gone wrong in it would be really helpful, I don't want to do the same thing in the exam when I can't check if it's right or not (so I can keep retrying it).
I don't suppose you could see where though, could you? I got a friend over just to check it, and neither of us could see where the mistake is. I mean, I know there must be one, I don't think I've broken maths, but I don't know WHERE it is.
Thanks for everyone's help so far!
As anticipated some algebraic mistakes :)
[tex]\int{z}^{2}{dz} = \int^{\pi}_{0}(sin\theta - 4sin\theta\cos^{2}\theta)d\theta + i\int^{\pi}_{0}(cos\theta - 4cos\theta\sin^{2}\theta)d\theta[/tex]
[tex]\int{z}^{2}{dz} = \left[- cos\theta + \frac{4}{3}cos^{3}\theta\right]^{\pi}_{0} + i\left[sin\theta - \frac{4}{3}sin^{3}\theta\right]^{\pi}_{0}[/tex]
[tex]\int{z}^{2}{dz} = ( 1 - 4/3 + 1 - 4/3)[/tex]
[tex]\int{z}^{2}{dz} = -2/3[/tex]
Thank you!
Oh my goodness, I see where it happened now, it was the multiplying out of the [tex]i(1 - sin^{2}\theta)cos\theta[/tex], I just ignored the [tex]-isin^{2}\theta\cos\theta[/tex] term (and the similar [tex](1 - cos^{2})[/tex] bit). I spent forty minutes yesterday on this really simple check of the Cauchy-Riemann equations for complex differentiation because I'd missed a minus sign from when I'd crossed through the thing next to it and obscured it slightly, and so something I knew was diffable kept telling me it didn't satisfy them. I do like maths, but I wish I could do the algebra more consistently not wrong.
Thank you! At least I know I wasn't doing the method wrong now, just apparently can't multiply and add.
