Thread Closed
guassian infinite sheet and charge with kinetic energy
Share Thread Thread Tools
Jun9-08, 11:57 PM   #1
two infinite sheets of charge (one positive, one negative) are arranged parallel to each other and separated by a distance of 2m. a charge of 3 microcoulombs is realeased at the positive plate. when it reaches the negative plate it has a kinetic energy of 0.6 joules. what is the electric field between the plates
2. Relevant equations
electric field of charge sheet E = sigma/2(epsilon_o) where sigma = charge density, epsilon_o = constant 8.85*10^-12
energy U = 1/2 CV^2 where C is capacitance, v is electric potential
C = Q/V where Q is charge, V is electric potential
3. The attempt at a solution
do i assume sigma as constant?
do i assume both sheets have the same electric field, so electric field between the sheets is the sum of the two?
how does the energy play a role in determining the electric field, the equation for electric field is already specified, and can be solved in terms of constants, assuming sigma is constant too.
if i use the energy and capacitance equation i get:
U = 1/2[(Q/V)(V^2)]
0.6 = QV/2
i am not sure how Q, V relate to electric field, i'm lost actually...
help appreciated
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jun10-08, 12:18 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Yes, yes. Constant sigma. Constant E field. Now start throwing out equations you don't need. Don't stop too soon. You only need one.
Jun10-08, 07:30 AM   #3
still somewhat lost, i did find in actuality that using :
U = 1/2[(Q/V)(V^2)]
0.6 = QV/2
V = 400000 volts when Q = +3*10^-6 coulombs
but how does V relate to electric field E?
Jun10-08, 09:25 AM   #4
Recognitions:
Quote by scholio View Post
U = 1/2[(Q/V)(V^2)]
0.6 = QV/2
You are CONSTANTLY using WRONG equations. Take U = 1/2[(Q/V)(V^2)]. What kind of a situation does that apply to? What's U, is it kinetic energy? What's Q? What sort of charge is it? Can it be the 3*10^(-6) coulombs? If you have a formula involving U,Q and V, that doesn't mean you can use it in EVERY problem that has the letters U,Q and V in it. Don't only remember equations, remember what sort of physical setup they apply to.
Thread Closed
Thread Tools
Similar Threads for: guassian infinite sheet and charge with kinetic energy
Thread Forum Replies
Electric Field for infinite sheet of uniform charge per unit area General Physics 10
Calculating the Kinetic Energy of a Point Charge From Far Away Introductory Physics Homework 0
[SOLVED] Kinetic Energy of a Charge Introductory Physics Homework 0
kinetic energy of a charge Introductory Physics Homework 4
infinite sheet of charge..just need help on sigma stuff Introductory Physics Homework 3
