How to test if a definite integral is finite or not?
The discussion focuses on determining the finiteness of definite integrals, particularly the integral of the function \(\int_{-\infty}^{\infty} e^{-2a \tanh^2(bx)} dx\). A necessary condition for the integral to be finite is that the integrand approaches zero as \(x\) approaches infinity. However, this condition alone is not sufficient. The discussion emphasizes that a positive or negative function must decrease faster than \(1/x\) for the integral to converge, specifically falling below \(x^{-(1+\epsilon)}\) for any \(\epsilon > 0\) beyond a certain point.
  • Understanding of definite integrals and convergence
  • Familiarity with the behavior of the hyperbolic tangent function
  • Knowledge of asymptotic analysis and limits
  • Basic principles of improper integrals
  • Study the conditions for convergence of improper integrals
  • Explore the properties of hyperbolic functions in integrals
  • Learn about asymptotic behavior and its implications for integrals
  • Investigate specific cases of integrals with parameters and their convergence
Mathematicians, physicists, and engineers dealing with integrals in their work, particularly those analyzing the convergence of complex functions with parameters.
arroy_0205
Suppose I have a complicated integral whose exact evaluation seems extremely difficult or may be even impossible, in such a case is there any way to tell if the integration result is finite or not? suppose the problem is
[tex] \int_{-\infty}^{\infty} f(x;a,b) dx[/tex]
I think there might be some conditions on the function involved. Actually the function contains some parameters also (a,b) which can be taken to be constants for a particular case. Now I am looking for a condition general enough to handle arbitrary parameters, ie, can I tell if the integral is finite for any arbitrary values of those parameters? If yes, then how or under what condition? Take as an example:
[tex] \int_{-\infty}^{\infty} e^{-2a \tanh^2(bx)} dx[/tex]
Is this finite?
I may be a little rusty. If I remember correctly, |tanh(bx)| -> 1 as x -> oo. In which case, the integral certainly is NOT finite. A necessary condition for integral to be finite with an infinite domain is the integrand go to zero as x -> oo. Also, this condition is not sufficient!
If i remember correctly, besides using definition you can use the fact that any positive (or negative) function has a finite integral, if its falling with a greater exponent than 1/x. (equivalently - if its below x^-(1+eps) for any x greater than some x0). It doesn't work ok for an alternating function.
This applies if you are interested in a true integral, not prime value. Also, this covers just what happens when x goes to infinity, not points where function itself diverges.
  • · Replies 27 ·
  • · Replies 16 ·
